Re: New to 3d printing with smartrap need some help August 05, 2014 07:14PM |
Re: New to 3d printing with smartrap need some help August 06, 2014 12:25AM |
Re: New to 3d printing with smartrap need some help August 06, 2014 09:10AM |
Re: New to 3d printing with smartrap need some help August 06, 2014 09:47AM |
Re: New to 3d printing with smartrap need some help August 07, 2014 04:17AM |
Re: New to 3d printing with smartrap need some help August 07, 2014 07:26AM |
Re: New to 3d printing with smartrap need some help August 07, 2014 07:45AM |
Re: New to 3d printing with smartrap need some help August 07, 2014 07:46AM |
Talle
I tried to print this yesterday but I was kind of unsuccessful due to stop in the hotend.
I belive that is PLA related since my hot-end-fan has been working flawless with other PLA rolles.
What I realized though was that the slide was a bit to thin so it wobbled a bit back and forth, so I´ve widened it a bit 0.1mm and also cut the corners, and made some minor adjustments.
I´ll give it another go tonight and keep you updated.
/Talle
[attachment 37928 NewX-endwJ-Headv2.jpg]
Re: New to 3d printing with smartrap need some help August 07, 2014 08:23AM |
I start to understand CAD ( after blender ) . lol . it's good time after one year smartap design hu ?|
Re: New to 3d printing with smartrap need some help August 10, 2014 12:56PM |
Re: New to 3d printing with smartrap need some help August 10, 2014 05:57PM |
BackEMF
i'm experimenting with this but when the arm is half way then it already struggles a bit and when the arm is fully extended then the slide tends to block / get stuck
However when I just press manually then it seems to be working just right.
So when the arm is extended the x bends enough to make an angle that gives enough force to get the slide stuck on the friction.
This resulted in some thinking and since I’m figuring out FreeCAD I decided to explore my ideas there..
And this is the (not so practical) result. Bur maybe someone can remix the ideas?
[attachment 38155 zipslide.jpg]
This is done with the Genie hot end in mind. the PEEK of the hotend functions as a slide.
The mount groove rests on zip ties that function as a spring as well.
and the heatsink is the trigger for the microswitch (and that is also held in place with ziptie pins)
It's a lot inspired by Japanese woodworking techniques. :-D
The main idea is to have the probing pressure fully centered in the slide so that the slide doesn't cause sidewards friction. And all the rest is pure to keep things small.
... just having some fun with FreeCAD
Re: New to 3d printing with smartrap need some help August 10, 2014 09:29PM |
Re: New to 3d printing with smartrap need some help August 12, 2014 05:41AM |
BackEMF
Re: New to 3d printing with smartrap need some help August 12, 2014 01:03PM |
Talle
BackEMF
I had the same problem initially but found it easier to lubricate the slider and X-end with silicon spray.
Made it slippery as hell and haven´t had any blocks/stuck since.
I use the J-Head MK5 and my design of the slider but it should be irrelevant in the design.
Re: New to 3d printing with smartrap need some help August 14, 2014 11:35AM |
Re: New to 3d printing with smartrap need some help August 14, 2014 11:44AM |
Re: New to 3d printing with smartrap need some help August 14, 2014 11:47AM |
Re: New to 3d printing with smartrap need some help August 22, 2014 01:12AM |
Re: New to 3d printing with smartrap need some help April 14, 2015 08:44PM |
