Re: New to 3d printing with smartrap need some help June 14, 2014 07:23PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 08:13PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 08:42PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 08:46PM |
duranza
How do you get the pictures to show in the forum?
Re: New to 3d printing with smartrap need some help June 14, 2014 08:49PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 08:53PM |
duranza
umm.. It never says it gets hotter than 180. I did set the thermistor to 7 like the manufacturer said. Also did a PID auto tune
Re: New to 3d printing with smartrap need some help June 14, 2014 08:54PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 08:56PM |
duranza
Also Reg, I can't get your auto level to work. In fact, I cant get the regular z offset to work right. I get it to home but the extruder is too low and drags.
Re: New to 3d printing with smartrap need some help June 14, 2014 08:57PM |
duranza
I do not have a thermometer. I wish I did. I'm going to try to load the original marlin that I was using with the other hot end to see.
Re: New to 3d printing with smartrap need some help June 14, 2014 08:58PM |
Anonymous User
Re: New to 3d printing with smartrap need some help June 14, 2014 09:09PM |
regpye
That first image shows a very lot of heat in that area, the PTFE has even melted, so it would have to be over 260C.
Re: New to 3d printing with smartrap need some help June 14, 2014 09:27PM |
I think you need to set it permanently after finding the correct offset.Quote
duranza
I'm using the lcd option where it says Z offset to adjust it, but It doesn't stay.
Re: New to 3d printing with smartrap need some help June 14, 2014 09:40PM |
Then one day, everything just came together and my little Smartrap is printing like a champ!|
Re: New to 3d printing with smartrap need some help June 14, 2014 10:45PM |
madmike8
The tube it comes with goes all the way down in the barrel. You cut it off flush with the top of the ptfe holder. You will use a m4 nut on your 4mm ptfe tube to mount it to the hotend holder.
[attachment 34896 image.jpg]
Anonymous User
Re: New to 3d printing with smartrap need some help June 14, 2014 11:05PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 11:09PM |
Anonymous User
Re: New to 3d printing with smartrap need some help June 14, 2014 11:24PM |
Re: New to 3d printing with smartrap need some help June 15, 2014 12:04AM |
Anonymous User
Re: New to 3d printing with smartrap need some help June 15, 2014 12:20AM |
Re: New to 3d printing with smartrap need some help June 16, 2014 11:26PM |
Re: New to 3d printing with smartrap need some help June 16, 2014 11:31PM |
Re: New to 3d printing with smartrap need some help June 17, 2014 11:01PM |
Re: New to 3d printing with smartrap need some help June 17, 2014 11:18PM |
duranza
Using an infrared thermometer on the brass tip of the extruder should show you the same temperature as in the screen right?
Re: New to 3d printing with smartrap need some help June 17, 2014 11:37PM |
Re: New to 3d printing with smartrap need some help June 17, 2014 11:42PM |
duranza
The thermometer seems to work right, but when I heat up my first metal hot end to 180, the tip only measures 100C, I get 120C at the stainless rod that goes to heat sink. The supplier says in the Flebay page that it is a 100k EPCO and I have it set at 1 in marlin
Re: New to 3d printing with smartrap need some help June 17, 2014 11:49PM |
Re: New to 3d printing with smartrap need some help June 17, 2014 11:52PM |
duranza
The hot end is wrapped in heat shield fiber cloth and I have the fan off. It is the first hot end that I started with. I've been messing around with it until I got the J-Head lite sorted out. The temperature difference would explain why my extruder kicks back. Maybe too much back pressure. How would I adjust the temperature to calibrate the thermistor?
Re: New to 3d printing with smartrap need some help June 19, 2014 09:44PM |
Re: New to 3d printing with smartrap need some help June 19, 2014 11:45PM |
duranza
Anybody have just the smartrap marlin file.. I've been trying to download from github but the whole repository takes for ever. I'm trying to get the auto level to work and I want to try a clean marlin file
