Re: New to 3d printing with smartrap need some help June 22, 2014 09:54PM |
duranza
I'm definitely not saying anything bad about the J-head Lite. Cheap, simple and works. <----- Love this... I'm just having noob problems and once I figure all that out it will be awesome. I do know where Regpye is coming from though. There's things we can't cheap out on to avoid headaches. Being on a really tight budget is what has made me who I am. It has made me resourceful. I don't let the lack of funds hold me back. Besides, I learn better by hands on.
I'm very happy that I'm printing after getting a replacement J-head from Ohio plastics. The first one the Teflon liner couldn't get down all the way even when heated to 250c. You should have seen my face when I saw filament coming out with the second one. Now I see why the wood mount too.. The plastic mound gets a little soft after an hour of printing.
The parts that I tryed from Regpye last night failed. Although I did learn alot from this. There is a lot more in the programing/slicing to get it right than everything else combined.
Looks like I needed more turns around the stepper shafts with the fishing line to get more friction. It slipped a little on the X and Y and the print was slanted. Also, I need to eliminate the strings between the parts.
Re: New to 3d printing with smartrap need some help June 22, 2014 10:01PM |
goldenmongoose
Haha, I understand Reg. No can of worms shall be opened. Maybe I shouldn't say everyone. Maybe just America loves cheap. I guess there's no Walmarts in the Outback to corrupt your socio-economic world view. Yet...
Re: New to 3d printing with smartrap need some help June 22, 2014 10:08PM |
MelT
Glad you sorted it out.
I too, had the slant on X before and just needed to tighten the fishing line. 5 turns on the shaft works for me.
What's your nozzle diameter? And at what speeds can you print now?
Anonymous User
Re: New to 3d printing with smartrap need some help June 22, 2014 11:45PM |
regpye
Yes no Walmart here thank goodness, but we still have some pretty bad things happening here too, and following USA too much. I hope we don't go down that track too far, it looks pretty bad.
Re: New to 3d printing with smartrap need some help June 23, 2014 12:20AM |
goldenmongoose
regpye
Nice try Reg, but I've been to Australia and it's a very nice country with very friendly people.
Re: New to 3d printing with smartrap need some help June 23, 2014 12:33AM |
duranza
.4 on the nozzle and I'm now printing at 25mm/sec. I'm going to give the extruder another try. Do you use slic3r or cura? I'm trying to get the settings right on slic3r. I also had to level the bed by shimming the plate as I still can't get it to auto level yet.
Re: New to 3d printing with smartrap need some help June 23, 2014 12:44AM |
regpye
Government corruption is everywhere, even here. Used to be called the lucky country, but not so lucky now. Highest taxes in the world, expensive postal system, lies and lies and more lies from the pollies, and rights being lost all the time. It has become a Nanny State for sure, being told what we can and can't do and more taxes added all the time.
Re: New to 3d printing with smartrap need some help June 23, 2014 01:30PM |
Re: New to 3d printing with smartrap need some help June 23, 2014 01:48PM |
Re: New to 3d printing with smartrap need some help June 23, 2014 03:00PM |
Re: New to 3d printing with smartrap need some help June 23, 2014 06:42PM |
A smaller fan will work too. You just need some air blowing on the cold end. Insulate your heating block so the fan won't cool it down. |
Re: New to 3d printing with smartrap need some help June 24, 2014 01:34AM |
goldenmongoose
regpye, cudos on the new hot end design. I wasn't refering to the performance of your hot end. But, it's easy to make an expensive hot end that works well with PLA. It's much harder to make an inexpensive hot end that works well with PLA. I saw you're hot end design and it looks cool. But, are there any source files available? I'm curious because it looks pretty long compared to most others. A standard J-head is about 2.5" and reg's is 4"?
Re: New to 3d printing with smartrap need some help June 24, 2014 07:44PM |
Re: New to 3d printing with smartrap need some help June 24, 2014 07:48PM |
duranza
Ok guys, I'm having problems with the prints being good in the first 2-3 mm and then it starts to be intermittent with the filament flow. Any Ideas? I'll post a picture in a bit
Re: New to 3d printing with smartrap need some help June 24, 2014 09:09PM |
Anonymous User
Re: New to 3d printing with smartrap need some help June 24, 2014 09:42PM |
Re: New to 3d printing with smartrap need some help June 25, 2014 12:20AM |
duranza
goldenmongoose
220 seems high for pla. I haven't had any problems with pla at 185. Running pla at high temperatures might be gumming up the works. I'd recomend setting the temp at 220 and purging the hot end while gradually decreasing the temperature.
You could also try increasing the torque on your stepper driver to stop your motor from being over torqued. Increasing the temperature may seem like an easy fix, but it doesn't fix the underlying problem.
Re: New to 3d printing with smartrap need some help June 25, 2014 09:49AM |
Re: New to 3d printing with smartrap need some help June 25, 2014 02:46PM |
Re: New to 3d printing with smartrap need some help June 25, 2014 06:10PM |
Re: New to 3d printing with smartrap need some help June 25, 2014 07:41PM |
Re: New to 3d printing with smartrap need some help June 25, 2014 07:58PM |
Re: New to 3d printing with smartrap need some help June 25, 2014 08:11PM |
BackEMF
Sounds a bit like the issues i had.
I now use Reg's geared extruder and hotend and that solved the them.
I still have a lot of details to figure out. With some prints the PVA doesnt stik good enough and with others i have to fight for several minutes to get a print loose :-)
Now experimenting with a fan to cool the print too. but that changes the game once again
).There wasn't much touching the glass.
(I slowed down the print while I did this)
Re: New to 3d printing with smartrap need some help June 25, 2014 08:56PM |
Re: New to 3d printing with smartrap need some help June 25, 2014 09:00PM |
Re: New to 3d printing with smartrap need some help June 25, 2014 09:02PM |
duranza
I'm going to slice RegPye's extruder one more time with cura and give it a try.
Re: New to 3d printing with smartrap need some help June 25, 2014 10:50PM |
duranza
I wish it had specific settings for overhang and bridge though. I work around that with the plugin but the setting applies for the whole level and not just where there's a bridge. But hey, it works.
regpye
Use at least 35% infill, more for the gears for best results.
Re: New to 3d printing with smartrap need some help June 25, 2014 11:12PM |
MelT
duranza
Exactly my thoughts. Slic3r to me makes nozzle moves that do not make sense. With Cura, it prints exactly how I would print it if I was a printerI wish it had specific settings for overhang and bridge though. I work around that with the plugin but the setting applies for the whole level and not just where there's a bridge. But hey, it works.
regpye
I used 40% fill without a problem.
Re: New to 3d printing with smartrap need some help June 25, 2014 11:29PM |
Re: New to 3d printing with smartrap need some help June 26, 2014 12:11AM |
duranza
Well the stepper motor gear came out great. Now on to the clamp, and tomorrow I'll try the big block...
