Re: New to 3d printing with smartrap need some help July 16, 2014 07:12PM |
Re: New to 3d printing with smartrap need some help July 16, 2014 07:29PM |
duranza
I'm using 10-24 stainless from home depot. It fits the stock frame good
Re: New to 3d printing with smartrap need some help July 16, 2014 07:37PM |
Re: New to 3d printing with smartrap need some help July 16, 2014 07:57PM |
Re: New to 3d printing with smartrap need some help July 16, 2014 10:13PM |
RTurnock
duranza
so that is size #10 and 24 threads per inch.
That is about 1/8 inch diameter threaded rod but the recommended 5mm rod is 60% longer diameter.
I am planning on a 22cm long Z axis rod to get 150mm Z height for printing.
Does #10 meet my requirements?
Re: New to 3d printing with smartrap need some help July 16, 2014 11:18PM |
Re: New to 3d printing with smartrap need some help July 16, 2014 11:33PM |
RTurnock
I am following this BOM. Is there a better one or more current one?
[attachment 36731 SmartrapBOM-whatisnecessary.pdf]
OK, thanks for the information on the threaded rod.
Re: New to 3d printing with smartrap need some help July 16, 2014 11:39PM |
Re: New to 3d printing with smartrap need some help July 16, 2014 11:54PM |
RTurnock
I saw a video of the Smartrap with the extruder working but the motor was on a table with the shaft pointing straight up and pushing filament through a bowden tube.........is that how you use your extruder?
Re: New to 3d printing with smartrap need some help July 17, 2014 11:55AM |
RTurnock
Where do people in USA buy M5 or M6 threaded rod?
I have been looking at McMaster Carr and they have only inches in that small a size.
I could buy a 1/4inch - 16 TPI or larger, and make changes in firmware to get the right steps per unit.
I am interested in a specific hyperlink to a specific product that people have already purchased and that works for you.
Re: New to 3d printing with smartrap need some help July 17, 2014 12:13PM |
Re: New to 3d printing with smartrap need some help July 17, 2014 12:49PM |
smartfriendz
Would it be nice to have the smartrap in imperial ?
i wonder..
Re: New to 3d printing with smartrap need some help July 17, 2014 02:29PM |
Re: New to 3d printing with smartrap need some help July 17, 2014 05:48PM |
Re: New to 3d printing with smartrap need some help July 17, 2014 07:42PM |
smartfriendz
thanks guys. That's pretty clear to me : no imperial ! ( but i like the name .. imperial smartrap..good for ego![]()
To be honest, i was a little scared because until i would redo the all design in something like openscad , I don't see when i could work on the adaptation , it's a lot of work , and i even couldn't test easy from France. I think the only imperial we have left here are those gaz plumbing stuff ? 1/8 5/6 ..etc ?
But.. I want to redo all in something like opens cad for all options ( 3 driving systems for axis, 6 / 8 mm rods, 1.75 / 3mm filament, direct drive / geared extruder .. etc..). All exists actually but i have hard time to maintain them all .
Re: New to 3d printing with smartrap need some help July 18, 2014 06:35AM |
Re: New to 3d printing with smartrap need some help July 18, 2014 10:12AM |
Re: New to 3d printing with smartrap need some help July 18, 2014 05:17PM |
BackEMF
Imperial is still nice to place on top of a car. The music industry replaced the 12 inch records with MP3, now that was a bad idea i admit, but now there is FLAC and everyting is ok in that department. Rack servers are still placed in 19inch racks that for some reason are never actually the same 19 inch for some strange reason.. Or are inches flexible in the 19inch range?
Wouldn't hurt to learn more about working with imperial but keeping things simple can be hard enough at times. Imperial seems to me more about capitalism these days, Demand Imperial designs and then be sure the money doesn't flow across the border, but then capitalism also increases the price of anything imperial that make the stuff many times more expensive and thus only helps to make the imperial industry fatter on the account of the working class.
Oe i got carried away there... :-) I even forgot to mention PCB designs where the imperial pinspacing causes a lot of headaches.
Switching from Imperial to metric isn't an easy thing... Imagine all the industrial machines out there based on imperial measurements, they still need to be repairable, not only spare parts but also a technician who still can cope with the imperial stuff. And you don't want a critical part of a nuclear reactor based on imperial be kept together with a metric bolt by accident.
All that said... yes please keep it metric!!
Re: New to 3d printing with smartrap need some help July 18, 2014 05:55PM |
Re: New to 3d printing with smartrap need some help July 18, 2014 09:39PM |
Re: New to 3d printing with smartrap need some help July 20, 2014 06:58PM |
duranza
It is definitely the most flexible design out there. What drew me in, was that it resembles a milling machine. Great job Serge.
Is it normal for the bowden tube to elongate/ stretch?
Re: New to 3d printing with smartrap need some help July 20, 2014 08:35PM |
Re: New to 3d printing with smartrap need some help July 20, 2014 10:23PM |
BackEMF
@ Regpye:
In the PCB designs i also see 5mm and 3,5 mm pinspacing winning some ground. But the mixed pinspacings can drive you wild since you never have the right grid....
Re: New to 3d printing with smartrap need some help July 21, 2014 08:51PM |
Re: New to 3d printing with smartrap need some help July 21, 2014 09:23PM |
BackEMF
Yes, i totally agree, would be a great solution to have dual grids.
For a single, single sided PCB i prefer to print a mirrored trace design with a laserprinter on glossy paper, and then transfer the toner by ironing it on a well cleaned copper clad PCB. (Ace tone works great to do the cleaning the copper, and also to remove the toner once it is etched)
For dual sided PCB i prefer to spend some extra time on the design and then order a small batch (10 pcs) I'm doing this with the ATX board I’m designing during coffee breaks.
Re: New to 3d printing with smartrap need some help July 21, 2014 09:45PM |
Re: New to 3d printing with smartrap need some help July 21, 2014 11:54PM |
BackEMF
fritzing.org
It's still Beta, but i like it much better then eagle. And it's not 'limited / annoying by design'. Eagle is more advanced and i hear the newer hobby-release is not as limited as before. But for now i stick with fritzing mainly because i moved away from eagle due to the limitations it used to have.
Re: New to 3d printing with smartrap need some help July 22, 2014 07:40AM |
Re: New to 3d printing with smartrap need some help July 29, 2014 10:49PM |
Re: New to 3d printing with smartrap need some help July 30, 2014 03:37AM |
