Re: New to 3d printing with smartrap need some help
July 30, 2014 05:24AM
Great thinking Duranza.
Would it be an idea to put the switch below? Then you have an easy way to slide the hot end out without screwing things loose.
Or is the switch also needed as a 'spring'?
July 30, 2014 07:52AM
My line of thinking exactly BackEMF. The switch provides some spring back to keep it down. Although once everything is on there (hot-end, fan) it should have enough weight to keep it off the switch.
Serge: The holes you see in the plate allow for adapters to be bolted on and be adjustable up and down. The slots allow fan air to pass through to cool the hot end. I will upload pictures and files tonight.
July 30, 2014 08:10AM
ho ok. i think i start to imagine how it is smiling smiley
thank you . I definitely want to try this one out ? I'm thinking about this part too. we have the two main problems there : 1- head not fixed enough 2- melting head support.
the Smartrap project
[smartfriendz.com]
[www.thingiverse.com]
[reprap.org]
[github.com]
doc assemblage: [reprap.org]
NEW: Forum smartfriendz: [smartraptalk.smartfriendz.com]
July 30, 2014 04:16PM
duranza
New smartrap probe/hot-end plate
Hey all, I have a little present for you guys. Take a look a this little mod. I will be testing it tomorrow and when all is good I will post some STLs for whoever wants to upgrade.
This will help out with eliminating the torque of the normal arm, as this only allows up/down movement.
I like it, very clever.
Can you send or direct me to the STL files?
I will make an adapter for the Genie hotends so that everyone can use that too.
[regpye.com.au]
"Experience is the mother of all knowledge." --Leonardo da Vinci
July 30, 2014 06:47PM
link to stl files
Here is what I have so far. I only have J-head adapter in there, but it is really easy to adapt to any hot end and bolt it to the slide. I'm taking apart my smartrap to test it out right now. I will post a video of it working later on.
July 30, 2014 07:31PM
Thank you duranza,
Going to try it right now ! looks good .. even if it's very big definition .. impressive smiling smiley
[smartfriendz.com]
[reprap.org]
[github.com]
July 30, 2014 10:13PM
Probing and printing
Well I'm even amazed myself. I knew it would work, but not this good. All of the flex on the glass is gone, and even with auto level the z axis barely moves now. I also had to get rid of the extra compensation for the last probe point as the glass now doesn't flex at all. I did end up having to use a rubber band to keep down pressure and keep it off the switch. I will work on getting a spring in there somewhere.
July 31, 2014 05:10AM
I just printed but not installed for now, but already by hand it seems to be indeed very good.
Can i steel your idea and adapt for both heads? ( huxley type). I need also to adapt the top to all three driving systems ( fishing line, racks&pinions and GT2) so the model will be maybe changed, but basically, it would be a real idea steeling tongue sticking out smiley
You found just something i tried before and failed miserably ! cool work smiling smiley
[smartfriendz.com]
[reprap.org]
[github.com]
July 31, 2014 07:50AM
smartfriendz
You can indeed. I can upload solid models if you would like, to make it easier to modify and keep the mesh light. I only put 2 holes in the bottom where I loop the fishing line through, but there is a lot of room to add GT2/ Rack and Pinion on the top.
July 31, 2014 01:26PM
Very nice Duranza!
July 31, 2014 05:50PM
Thank you smiling smiley
solid model is wonderful of course .. i'm still learning free cad , but have hard time with it .. I know it's bad , all smartrap is designed with blender .
For now. i would love redo the design in opens cad, so we could integrate all options in the code and put some interface on a website to generate stl with lot of different choices.. I just miss time !
[smartfriendz.com]
[reprap.org]
[github.com]
July 31, 2014 06:03PM
I put some parasolid files in there. Let me know what works for you.
July 31, 2014 06:11PM
Thank you duranza,
If it doesn't work. i will redo in blender anyway .. Now i have the model, it's so much more simple to do smiling smiley
thank you again..it will be a nice update to the model .
[smartfriendz.com]
[reprap.org]
[github.com]
July 31, 2014 10:05PM
smartfriendz
I have just made an adapter for the genie hotend.
Print out duranza's design just as duranza designed it and add these two parts that mount the hotend and also a 30mm fan with a cowl.
STL files can be found here
GenieMount
Edited 1 time(s). Last edit at 07/31/2014 10:06PM by regpye.
[regpye.com.au]
August 01, 2014 07:47AM
Wow very cool fan cowl integration. I like it.
August 01, 2014 07:48AM
duranza
Updated version now ready:
All parts
Fan cowl
Sliding base
The sliding base has been designed to be tapped with a M3 tap. Print this small part at 40% fill or more.
Edited 1 time(s). Last edit at 08/01/2014 09:11PM by regpye.
[regpye.com.au]
August 01, 2014 09:40PM
I like where this is going. Interchangeable hot-ends already bolted to the slide. Now if we can make the wires with some sort of plug in/ disconnect we would just move the switch, and slide the new one in.
August 02, 2014 01:12AM
duranza
Here is a captive nut version so that no tap is required for the M3 bolts.
It is just the slide part, you will need to download the previous design and then use this with it.
captive nut version
[regpye.com.au]
August 02, 2014 01:00PM
niiiice smiling smiley
I like the connector idea. i think it would be nice if ramps had 6 terminal connectors for hotend, fan and bed instead of the screw terminals
Anyway, thats what i'm going to do on the next build..
5.08 pitch terminal connectors
August 03, 2014 08:33AM
Are there any original files available? My PC is not powerfull enough to convert the mesh back into a solid that i can edit in FreeCAD.
August 03, 2014 09:05PM
BackEMF
All my files are in Alibre Design, so maybe you wont be able to use those either?
[regpye.com.au]
August 04, 2014 06:50AM
Looks awesome!!
Can anybody make one for Huxley hotend and 8mm X rods?
August 04, 2014 07:38AM
Sogeking
Looks awesome!!
The main plate is 8mm. I will make a slide attachment for the huxley, unless Serge has already done so.
August 04, 2014 07:41AM
OK, great! Thanks a lot.
Very clever design.
August 04, 2014 08:42AM
regpye
duranza
All parts
Fan cowl
Sliding base
Thx for this!
I really like it! smiling smiley
Just a quick question.
Has the main part of this been edited aswell in the latest version?
Printed just the sliding base and that is a great deal smaller than the original part in my print.
or is it just my print that is bad (made 2 copies).
Main part is with 100% fill and Sliding base with 50%.
THX
Edited 1 time(s). Last edit at 08/04/2014 08:43AM by Talle.
open | download - bild 1.JPG (397.1 KB)
open | download - bild 2.JPG (374.6 KB)
August 04, 2014 06:35PM
Talle
regpye
duranza
All parts
Fan cowl
Sliding base
Thx for this!
THX
The main base is the original file.
The other two parts are made to fit as close as could be from just measurements as I didn't have the raw file for the main part.
The parts all fit together nicely on mine.
All parts were printed at 55% for mine prints.
I will try and make it a bit tighter so that if too tight a file may be needed to trim it up a bit.
[regpye.com.au]
August 04, 2014 07:33PM
The original files had a .1mm gap between the main plate and the slide plate already built in.
Hey Reg, I think what would help on the Genie parts is to put a straight fillet on the corner of the 45 degree slide part so that only the sides make contact.
August 05, 2014 01:19PM
I guess they finally fixed the forum.. It was so slow last night I couldn't post anything
August 05, 2014 05:23PM
duranza
Update:
[regpye.com.au]
August 05, 2014 06:09PM
Looks like a good fit. I really like that blue color.
