Djinn5150's Smartrap Build June 24, 2014 10:32PM |
Re: Djinn5150's Smartrap Build June 24, 2014 11:17PM |
Re: Djinn5150's Smartrap Build June 24, 2014 11:51PM |
Re: Djinn5150's Smartrap Build June 25, 2014 12:23AM |
Re: Djinn5150's Smartrap Build June 25, 2014 12:46AM |
Now you got me thinking, I was planning on expanding the y-axis out and turning the print bed 90 degrees and having the sticker on the underside. Now I'm thinking I might be able to model that up in sketch up and print it up as a z-spreader/support with the z-rods in the wrench ends...hmmmm ideas ideasQuote
MelT
I better find a way to put that sticker somewhere in my machine.![]()
Maybe I will 3d print it and put it in the support between the two z-rods
Re: Djinn5150's Smartrap Build June 25, 2014 03:04AM |
Re: Djinn5150's Smartrap Build June 25, 2014 10:39AM |
Re: Djinn5150's Smartrap Build June 25, 2014 02:18PM |
Re: Djinn5150's Smartrap Build June 25, 2014 07:00PM |
djinn5150
madmike8
Looks good.
Are you looking at the same picture I am? Its a mess lolIt will come around in time, now that I have a feel for whats going on and what I "need" etc.
In all seriousness, thank you! There will be many more changes down the line.
Re: Djinn5150's Smartrap Build June 25, 2014 07:31PM |
djinn5150
Yes its definitely an old PSU, I had added some led's to the 5v rail in hopes it would alleviate the problem, but I was not so lucky. I think today Will try powering the Arduino off it and see if that is enough draw to keep it alive. Going to need to do that anyway if I want to upgrade to a stand-alone at some point.
Re: Djinn5150's Smartrap Build June 26, 2014 12:05AM |
regpye
Using the old power supplies we use to add a load resistor between the green wire and a black one, that held the power supply in the "on mode"
You should be able to do it by connecting the green wire from the power supply to the pin on the RAMPS that does the automatic turn on and off.
That pin is next to the reset button, the closest on the left when the reset button is facing you.
Re: Djinn5150's Smartrap Build June 26, 2014 05:39AM |
Re: Djinn5150's Smartrap Build June 26, 2014 04:38PM |
NO MORE CD ROM, between the 2 only pulling .25amp so hopefully not to much wasted juice. Going to change my firmware for the PSU defualt off and include a m80 in the startup and an m81 in the end code. To save on wasted electricity. Running a short test print now to see how it handles the load overall.|
Re: Djinn5150's Smartrap Build June 26, 2014 08:04PM |
Re: Djinn5150's Smartrap Build June 26, 2014 09:46PM |
Re: Djinn5150's Smartrap Build June 26, 2014 10:01PM |
Re: Djinn5150's Smartrap Build June 26, 2014 10:49PM |
MelT
Good that direct drive is working for you.
I wonder how powerful a taller motor is compared to a shorter one. Maybe enough to not need a geared extruder.
Re: Djinn5150's Smartrap Build June 27, 2014 02:25AM |
Re: Djinn5150's Smartrap Build June 27, 2014 05:55AM |
Re: Djinn5150's Smartrap Build June 29, 2014 02:37AM |
Re: Djinn5150's Smartrap Build June 29, 2014 10:21PM |
Re: Djinn5150's Smartrap Build June 30, 2014 07:49AM |
Re: Djinn5150's Smartrap Build June 30, 2014 01:04PM |
Re: Djinn5150's Smartrap Build June 30, 2014 04:10PM |
Re: Djinn5150's Smartrap Build July 01, 2014 11:14PM |
Re: Djinn5150's Smartrap Build July 01, 2014 11:37PM |
djinn5150
I can't even begin to describe how happy this makes me...
I'll pick up hardware tomorrow I think. I have a belt that I scavenged from an old scanner, but I don't have a drive gear, does anyone know where to find a printable one? I have searched and printed a few but nothing is matching up right.
Re: Djinn5150's Smartrap Build July 05, 2014 06:10PM |
Re: Djinn5150's Smartrap Build July 05, 2014 06:27PM |
djinn5150
Where are my manners? Thank you Regpye for the link on the gear generators, I did end up going another route as my belt was just not going to work. So I made a few modifications to parts I had in hand and am evolving to a rack and pinion drive, at least for now.
Have to really re-arrange everything to accommodate the wider Y plate, so hopefully I will have it back up and running in the next day or two. Looks like I will have to really button down my wires this go round, I have been meaning to do that anyway so why not just get it done.
Re: Djinn5150's Smartrap Build July 05, 2014 06:42PM |
Re: Djinn5150's Smartrap Build July 05, 2014 06:47PM |
