Rack and Pinion drive July 01, 2014 11:28AM |
Re: Rack and Pinion drive July 01, 2014 12:09PM |
Re: Rack and Pinion drive July 02, 2014 08:55AM |
Re: Rack and Pinion drive July 02, 2014 10:37AM |
Re: Rack and Pinion drive July 02, 2014 11:01AM |
Re: Rack and Pinion drive July 02, 2014 11:40AM |
I've learned it and used it for 3d animation before, so i knew it well. I know it's quiet..surprising, for someone coming from other softwares
Whe you know it, it works not that bad . I use booleans a lot to have something a little like CAD program. But i see the limits now.
I think Smartrap 2 will be in free cad or openscad fully .|
Re: Rack and Pinion drive July 02, 2014 11:44AM |
Re: Rack and Pinion drive July 02, 2014 12:06PM |
, less space on the desktop ..
Re: Rack and Pinion drive July 02, 2014 12:25PM |
Re: Rack and Pinion drive July 02, 2014 03:26PM |
It's true i've used the common racks out of opens cad with this.. i forgot
so much changes lately ..|
Re: Rack and Pinion drive July 02, 2014 03:37PM |
Re: Rack and Pinion drive July 02, 2014 04:03PM |
Re: Rack and Pinion drive July 18, 2014 04:03AM |
Re: Rack and Pinion drive July 18, 2014 09:24AM |
Re: Rack and Pinion drive July 18, 2014 10:18AM |
Re: Rack and Pinion drive July 21, 2014 12:36AM |
CellJeffe
Someone in another forum mentioned "sinusoidal" herringbone gears. That has me intrigued. Presumably, the helical gear mesh path develops sinusoidal error as the meshing teeth progress along the slant. A sinusoidal mesh pattern might compensate -- double it to a herringbone pattern to cancel the axial thrust. Unfortunately, the only thing I can find on sinusoidal herringbone gears are a set of patents from 1920. Unfortunately, he does not go into any advantages it might have.
Process for cutting gear wheels
Sinusoidal gearing
Re: Rack and Pinion drive July 21, 2014 10:40AM |
regpye
Why not use a straight rack? That would overcome that problem. Easier to print out too.
