Problems with the leveling August 13, 2014 03:46AM |
Re: Problems with the leveling August 13, 2014 07:43AM |
Re: Problems with the leveling August 14, 2014 06:50AM |
Re: Problems with the leveling August 19, 2014 07:11AM |
Re: Problems with the leveling August 24, 2014 03:10PM |
Re: Problems with the leveling August 24, 2014 05:18PM |
Re: Problems with the leveling September 04, 2014 04:20AM |
Re: Problems with the leveling September 04, 2014 06:03AM |
Re: Problems with the leveling September 06, 2014 10:51PM |
Re: Problems with the leveling September 13, 2014 09:14AM |
Re: Problems with the leveling September 13, 2014 03:32PM |
Re: Problems with the leveling September 13, 2014 04:15PM |
Re: Problems with the leveling September 15, 2014 02:52AM |
Re: Problems with the leveling September 15, 2014 05:34PM |
Re: Problems with the leveling September 15, 2014 07:45PM |
Re: Problems with the leveling September 15, 2014 10:33PM |
mikefiatx19
The G29 in the slicer code takes care of any angle in the plane of the glass. The 3 point level reads the height of the bed at 3 points and records the angle to use as a reference for the gcode commands. If you watch a print after the 3 point level has happened you should see the Z screw constantly turning to compensate for the uneven bed.
The only time I can think of when this would not work correctly is if the glass was somehow bent and like you said i think thats unlikely to happen.
Re: Problems with the leveling September 16, 2014 03:00AM |
Re: Problems with the leveling October 11, 2014 10:55AM |
Re: Problems with the leveling October 11, 2014 06:10PM |
Re: Problems with the leveling October 12, 2014 02:24AM |
Re: Problems with the leveling October 19, 2014 06:07AM |
Re: Problems with the leveling October 19, 2014 08:38AM |
