Heat-shrink tubing close to the hotend? September 05, 2014 05:30PM |
Re: Heat-shrink tubing close to the hotend? September 05, 2014 05:56PM |
Re: Heat-shrink tubing close to the hotend? September 05, 2014 06:26PM |
cristian
Hi smartrappers,
here comes a newbie question.
I have noticed that it is quite common to use heat-shrink tubes to insulate wires close to the hotend (or even inside, as for the thermistor).
Is it okay for long term use? Most of those (cheap) tubes are rated for 125°C, not more.
Wouldn't it be better to use kapton tape?
Cristian
Anonymous User
Re: Heat-shrink tubing close to the hotend? September 05, 2014 06:44PM |
Re: Heat-shrink tubing close to the hotend? September 06, 2014 03:56AM |
regpye
I use and supply PTFE sleeve that is only 0.5mm ID to the thermistor leads. The leads are joined to longer wires and the joint is covered with heatshrink tube, it doesn't get hot enough to affect it in any bad way.
I have done hundreds like this without any failures.
Robert_Paulson
Still, not worth the risk. I use PTFE heat shrink tubing. It's a little expensive, but vinyl @ 200C is a bad idea. Even if 1 out of 1000 fail, it's not worth saving the 5 cents it takes to use the right material for the job.
Anonymous User
Re: Heat-shrink tubing close to the hotend? September 06, 2014 11:39AM |
