fabrap 1.0
September 20, 2014 08:30AM
hi everyone
i have a smartrap 0.48, with rack and pinion
as i need a bigger printing size i made this new design
i started with regpy model , then click everywhere in solidworks and voila
source file here: [www.thingiverse.com]
[www.youtube.com]
thanks serge, regpye and john L
open | download - 1.JPG (264 KB)
Re: fabrap 1.0
September 21, 2014 08:28AM
Nice one, how its workin compering to normal smartrap version? smiling smiley
I have also wanted bigger print volume, but I have only changed the whole base, and supported the whole printer with rods. Now it's able to print 25x25x26cm grinning smiley
Im still callibrating it smiling smiley
Re: fabrap 1.0
September 21, 2014 10:47PM
give me some days to fully test it
i will then report here
Re: fabrap 1.0
September 23, 2014 08:55AM
bom added on thingiverse
Re: fabrap 1.0
September 23, 2014 11:59PM
Ooo thats a nice wide buildspace!
Looking forward to see it print!
Re: fabrap 1.0
September 24, 2014 11:50AM
little test part
[www.youtube.com]
Re: fabrap 1.0
September 24, 2014 02:08PM
Nice one, how you callibrated your printer that the corners of the print are not lifting?
Im also using the glue method that Serge has mentioned some time ago, but I must use the brim. Other way my corners are lifting :/
Re: fabrap 1.0
September 24, 2014 11:31PM
first layer is important. you need to adjust z offset to have the first layer squished on the glass a little bit ( to have a good grip on the glass)
i never had lifting on my print
maybe it is the wood brand
i use this one
[www.dropbox.com]
Re: fabrap 1.0
September 24, 2014 11:33PM
Nice one Fabrice!
Verteez:
I think there are several things involved.
The type of glue.
The properties of the filament. Some PLA has more crimp then other
The room temperature (the colder the room the more the crimp)
The temperature of the plastic when it leaves the hot end, If you print to hot then there is also more crimp.
I have fillament that has a rated temperature of 195-200C
If i print @ 195C or lower then The PLA doesn't stick very good to the bed.
And from 200C and up the hotter i print the more the PLA crimps when it cools down, and the corners start to curl up.
Also, the larger the object the more tension the crimp causes on the edges.
Re: fabrap 1.0
September 25, 2014 01:02AM
You re right
I remember i add brim for the plate y and z ( large rectangular part)
Amount of heat in the part is also important
Same part in 0,3 can have corner lift up and in 0,1 not
But it will take 3 time more to print
Re: fabrap 1.0
September 25, 2014 05:03AM
fabrice974
little test part
[www.youtube.com]
Prints very nicely, well done.
[regpye.com.au]
"Experience is the mother of all knowledge." --Leonardo da Vinci
Re: fabrap 1.0
September 25, 2014 09:00AM
thanks regpye
2 more little test
[youtu.be]
[youtu.be]
Re: fabrap 1.0
October 29, 2014 12:15PM
Cool design. I'm going to try and implement it with 3/8" (9.53 mm) aluminum rod and printed bearings. I've found the rod really cheap at $10 per 8ft at Menards ( Store in midwest). I'm sure Home Depot, Lowes, etc. carry something similar. I'm going to try a lightweight direct drive extruder on the x-axis. I'll post results as soon as I get it setup. Have you tested entire build surface for XL print yet?
Edited 2 time(s). Last edit at 10/29/2014 12:19PM by runninfarmer.
Re: fabrap 1.0
October 29, 2014 01:38PM
cool.waiting for your picture
yes, i tested on 280mm * 380mm and it works great
Re: fabrap 1.0
November 24, 2014 10:29PM
now
full gt2 version
result soon
open | download - 1_resize.JPG (80.1 KB)
Re: fabrap 1.0
November 24, 2014 10:53PM
fabrice974
now
full gt2 version
result soon
I like it.
The design looks very familiar ha..ha..
What have you added to the Z axis, the drawing is not clear on that area?
[regpye.com.au]
Re: fabrap 1.0
November 25, 2014 02:17AM
with this, everything should be clear cool smiley
[www.dropbox.com]
Re: fabrap 1.0
November 25, 2014 04:13AM
fabrice974
[www.dropbox.com]
After looking at the edrawing, I can see that it should work fine.
Very nice design. You need a good hotend to go with that.
[regpye.com.au]
Re: fabrap 1.0
November 25, 2014 12:14PM
i will start with my jhead
will try to buy one from you in a couple of month
Re: fabrap 1.0
November 26, 2014 05:48AM
Interesting glass clamps too.
Re: fabrap 1.0
November 27, 2014 07:45AM
yes
i want to add possibility to avoid automatic leveling
(stl files are still on my forum [fabrap-3d-printers.com])
Re: fabrap 1.0
December 13, 2014 02:29AM
first movement (x and z )
[www.youtube.com]
no counterweight
from 500 to 20000 mm/min
z belt is the way to go !
Re: fabrap 1.0
December 13, 2014 02:39AM
fabrice974
[www.youtube.com]
no counterweight
That is well thought out, I like it
[regpye.com.au]
