Re: I don't get out of the beta status... October 22, 2014 04:47PM |
smartfriendz
ho boy ... tha'ts bad . I really didn't know it could be a problem those 6mm
sorry about that . .. I will have a look how to re-integrate the all 8mm version . It doesn't change so much for me .
thank you for your feedback by the way. it's very interesting
Re: I don't get out of the beta status... October 23, 2014 03:56AM |
Re: I don't get out of the beta status... October 23, 2014 05:40AM |
Re: I don't get out of the beta status... October 23, 2014 05:49AM |
Xhnnas
Maybe you really had a good supplier. I did't wanted to buy at aliexpress because of bad experiences with electronics. I see, you added on github new 8mm version, correct? What about a new allignment of the X axis rods? Instead of horizontally, vertically like the fabrap? Or did you have any special plans for the next version?
Re: I don't get out of the beta status... October 23, 2014 09:28AM |
but the real reason is history reason : at the beginning, i couldn't have the Z rods to be turned 90 because it made a base plate too big for the printer i had ( limited to 100x100 printing size). I know it''s crazy but it's true.
Re: I don't get out of the beta status... October 23, 2014 04:18PM |
smartfriendz
To be honest, i didn't want to be too much like the printrbotbut the real reason is history reason : at the beginning, i couldn't have the Z rods to be turned 90 because it made a base plate too big for the printer i had ( limited to 100x100 printing size). I know it''s crazy but it's true.
I think i will try to have a version like regpye did very soon.. it's obvious we get more stability on the axis we have forces ... in our case , the X axis with forces against Z down !
about the 8mm, i maintain this version for the first kits ..and of course for anyone who prefer 8mm rods.
I just cleaned up github very hardly ! only the last version stays now ( old version are accible via history).
I will use a dev branche for next version.
Smartrap V2 should be completely different . I would like to have the bed not moving and still a good support for the head to be able to develop multi heads , seringe for food , laser cut, etc...
let's design
Re: I don't get out of the beta status... October 23, 2014 08:41PM |
smartfriendz
Smartrap V2 should be completely different . I would like to have the bed not moving and still a good support for the head to be able to develop multi heads , seringe for food , laser cut, etc... let's design
Good to see you all are doing well. |
Re: I don't get out of the beta status... October 23, 2014 11:50PM |
Re: I don't get out of the beta status... October 24, 2014 01:04AM |
smartfriendz
hi mark ,
It's good you've been busy ! I know freecad takes you a lot of time and everyone must be happy of your energy in the project
yes, beeing printable is no 1 . I even think about even more printable and less extra parts . I've always said there must be at least one project like this as the others went all to metal . I understand perfectly why of course and it's really normal they do . They call me crazy to insist at doing a reprap with lot of printed parts ( hard to produce, long, not enough rentability ).
I'm working on two separate main design things : 1- scara arm , like morgan but all printed with pinions 2- core xy , with all printed too, a little like the tantilus, but more efficient in parts . I admitt i try to have a box structure so it's easy to handle . Maybe we will loose print size at first.. nothing is certain of course, i must go forward with the design.
One extra domain related to the smartrap passionating me is the printed parts production with smartraps farm. I do believe it's reliable, if you have enough machines running .
I hope this new version will be made in freecad. I start to understand it far better. I'm still have a bad experience on changing sketches constraints after a part is finished. It always makes me some problems but i don't really know why .
) I'm thinking one could get a 250x250x??? mm into less than a 350x300 footprint.
I'v been doing some research on this too...|
Re: I don't get out of the beta status... October 24, 2014 02:41AM |
Re: I don't get out of the beta status... October 24, 2014 04:11AM |
it's hard to decide, i think i will try all solutions before starting some shared thoughts about the design in a thread. But i want to do that for sure .. i would be very happy to have a design that is done from a community .. maybe try to find a real time shared 3d design software ? lol . |
Re: I don't get out of the beta status... October 24, 2014 04:32AM |
markstephen
smartfriendz
Are you thinking about a coreXY - "Smartrap style" - or something else? I have been giving some thought to coreXY type my own self, with the #1 design criteria being ALL printed parts have to be printable on my Smartrap.
On a personal note, sorry I haven't been around more, got really busy with other stuff as well as the FreeCAD project, and there are only so many hours in a day... Just a shame there are only 24 of them, I would be happy with something like 32 or so...Good to see you all are doing well.
@ regpye - Did you do anything with that 2 into 1 hotend setup?
Mark
Re: I don't get out of the beta status... October 26, 2014 03:22PM |
Re: I don't get out of the beta status... October 27, 2014 04:57AM |
on the precedent version with blocked nut in the Z plate, you would or break the glass , or break the all Xplate. I did 4 or 5 times and it's fast ! nema17 on a screw has nice power ..enough to break a PLA structure. So this new system has the benefits to save the material
IT is also an anti wobble system, so the vibrations in X and Y of the thread are notreported to the head. I noticed better prints with layers since we have this system.
the "insert guides and done" system is great but need a very precise holder dimension .. too small and dit brakes, too large and the guides are out.
