Preparing to Build... Some Questions October 01, 2014 03:49AM |
Re: Preparing to Build... Some Questions October 01, 2014 03:42PM |
cosmicr
Hello All, I'm a MendelMax 1.5 user, planning to print off the parts and build a 0.4.9 SmartRap.
First and foremost, what layer height do you recommend? I'm thinking 0.4mm? I'm using PLA.
I've gone over the BOM and had a look at the instructions, but have a few questions about sourcing the components and building:
1. I'm assuming the design I'm printing allows for the newer auto-levelling (ie no servo)? Bed levelling was/is the biggest problem I've had with my MM1.5.
2. I'm planning on using a JHead. I've never used a Bowden extruder before. (not really a question)
3. I want to use 3mm filament since that's what my current printer uses. What changes will I need to make to do this? The Bowden Tube, what else?
4. Sourcing the smooth rods in Australia might be difficult for me. Why are the X and Y 295mm? Would it matter if they were 300mm? It would only mean longer pulleys right?
5. I'm planning on using GT2 Gears and Pulleys
6. Also planning on using MK7 Drive Gear.
7. I'm going to assume any 5 amp 12V power supply is okay? What if I decide I want a heated bed later, what should I aim for?
8. I'm going to source a lot of this stuff from Aliexpress. Any suggestions for otherwise?
9. I see the bowden head on the instruction pictures have a rather large aluminium cooling block. Will I need this for JHead? It's not in the BOM.
10. There appears to be a few things in the pictures that aren't in the BOM. Such as the little (rubber?) rings on the glass bed for attaching to the printer, and the rainbow ribbon cable (which is easy to get I suppose).
All in all a great looking printer, I love the simplicity of the design, and can't wait to get started.
Re: Preparing to Build... Some Questions October 02, 2014 12:42AM |
cosmicr
Re: Preparing to Build... Some Questions October 07, 2014 12:01AM |
Re: Preparing to Build... Some Questions October 07, 2014 12:27AM |
cosmicr
Thanks for the replies guys. I've started ordering parts. I've changed my mind on JHead and am thinking the E3D head... Will see when I get to it. Will stick with 1.75mm unfortunately, since it might be too much trouble to go to 3mm.
I've been attempting to print off the parts on my Mendelmax 1.5, and am having a really hard time. The build plate is the biggest thing I've ever tried. I'm using white standard PLA from 3dprintergear.com.au and it's not playing nice But that's a problem for someone else. Is there a BOM for the printed parts so that I might do each one individually? I'm printing at 0.3mm, using a raft, because my bed isn't very level.
Reg I'll keep in mind that you're in Aus. I'm from Melbourne. I'm curious, where do you source most of your parts from? Mainly I'm struggling to find hardware (ie rods, lead screws, etc). Electronics is fairly easy, although I'm concerned about quality.
Thanks again, and as soon as I have them I'll post photos.
edit: also if anyone's interested, here's my own BOM I've been keeping: BOM Link
