Hi smartrappers,
after some weeks playing with our wonderful toy I decided to share my experience about printing some of the exotic filaments that are available nowadays (and more are being invented every day: has anybody tried
this or
this yet?) with a Smartrap.
I
previously wrote about the problems that I encountered with the standard hotend supplied with the Smartrap, although some of them came because of an improper assembly. To make a long story short, I decided to get
Regpye's in the hope of having a more forgiving hotend, so I will report my printing experiences with Smartrap mounting this instead of the Huxley (that I abandoned).
This is not to say that the Huxley hotend does not allow you to print with the same materials (I failed with some of them, maybe somebody else will succeed), but I can for sure state that Regpye's hotend is indeed much more tolerant in terms of possible combinations of printing speeds and temperatures: with the majority of the materials, if you choose a temperature, you can vary the printing speed considerably without any issue, or the other way around, if you choose a printing speed you can vary considerably the temperature. So it is much easier to find good printing parameters to optimize many things at once (good layer adhesion, cleanness of the pieces, layer height, etc) without fearing clogs.
However every exotic material represents a sort of challenge, because of issues related either to the melting process or to some mechanical constraints.
In the following I will report my experience about the following filaments: Colorfabb XT, Colorfabb woodFill fine, Colorfabb bronzeFill, 3DPremium soft filament, Filimprimante3d PVA and Ninjaflex.
Colorfabb XT
I can confirm all the enthusiastic comments about this filament. It is incredibly strong, almost odourless while printing, and the transparent version (
now they made coloured versions too) looks like crystal.
The only problem is the need of a heated bed, so
bed adhesion is very, very difficult if you have a classic Smartrap
without heated bed as I have. Nevertheless, since I am too lazy to change the printing bed, I managed to make it stick a little to glass coated with PVA glue by squeezing a lot the first layer (something like 300% or 400% of the layer height, or even more) at a temperature of 240°C and at a ridiculous printing speed of 1mm/s (no mistake here). This way it sticks enough to the bed to print whatever you want, provided that you avoid any warping of the piece or the collisions with the printer head may make the piece detach from the bed while printing.
I found no problems with Regpye's hotend (using either 0.5 or 0.3 mm nozzle) even pushing it beyond the normal printing temperature. It withstood well 240°C (at least for a relatively short time of some minutes) and 220°C (for several hours). Since Regpye's hotend is very precious to me (it works great and I have only one for now) I will not dare to go beyond these temperatures for the moment.
WoodFill
The premise: results are amazing, at the touch if feels like wood (it smells like that when you print!), you can even sand it.
However this is really the most evil filament I have ever dealt with so far. It breaks so easily (handle the filament with a lot of care!), it becomes soft already at low temperatures, if you go slightly beyond its printing temperature or if you just extrude it too slowly it gets like vitrified (glossy and so viscous that it is impossible to extrude), finally it sticks to PVA glue coated bed as if it were its only raison d'être: it will never pop off even if you pray for it on bended knee.
This is actually the filament I have not been able to print with the Huxley hotend and that gave me a lot of problems even with Regpye's, because of the very frequent clogs.
In the end I discovered the simple recipe:
keep the temperature not high (for me not beyond 200°C) and
make sure the filament will always flow regularly and not too slowly: about (7 mm
3/s) of material works for me, corresponding roughly to a flow of 2.5 mm/s of filament with diameter 1.75 mm, or to an average printing speed of 40 mm/s with a layer height of 0.25 mm and width of 300%.
Otherwise, you may foresee a clog when the extruded filament becomes glossy and slightly darker than normal.
To reduce bed adhesion, it is enough either to lower the temperature of the first layer, or to increase the printing speed or to turn on the fan. With the right combination the pieces will pop off reasonably well.
Bronzefill
Another filament with amazing properties: it shines if you polish it well enough. Not much more to say except that this is even harder to detach from the PVA glue coated bed than woodFill, if possible. For the rest, it extrudes very well (at least with a 0.5mm nozzle, I have not tried smaller ones yet but it looks like it should work).
Flexible filaments: 3DPremium soft filament, PVA and Ninjaflex
The most tricky part of using soft filaments with a Smartrap (at least with my version) is that
the filament bends before entering the Bowden. In this post I described a partial fix for the problem, that makes possible at least to use them at ridiculously low printing speeds (2mm/s for the Ninjaflex because of its extreme flexibility, slightly faster with 3DPremium soft filament and PVA). The filament drive and the Bowden (that makes retraction not very effective) are the two main limiting factors. I am quite sure that printing speed can be reasonably increased with a little re-design of the filament drive, I will update this thread as soon as I manage to do it.
PVA sticks very well (meaning that it stays in place when it has to and pops off easily when you try to detach it) to the PVA glue coated glass, while with 3DPremium soft filament and Ninjaflex you have to take a bit more of care and squeeze them on the bed as described for the Colorfabb XT filament, but then they stay attached to the bed much better than the XT.
No problems about extrusion instead, even with 0.3 mm nozzle.
Some pictures
Here are some pictures, sorry for the low quality.
From left to right: a ring made with woodFill (as it came out of the printer), the same ring made with bronzeFill (sanded a little but not polished, I do not have all the tools yet...) and a die made with woodFill (after some sanding).
Two buttons printed with woodFill: on the left a curved button after some sanding, on the right a flat button as it came out of the printer.
From left to right: Colorfabb XT, Ninjaflex and woodFill (not sanded).
So, to conclude, thanks Serge and Regpye for providing us with these extraordinary tools and happy printing to everyone!
Cristian
Edited 3 time(s). Last edit at 10/19/2014 06:17PM by cristian.
