Re: Printing quality: pursuing perfection November 21, 2014 09:43PM |
cristian
BackEMF
why not use GT2 belt?
The only Smartrap design I saw so far with belts on the Z axis is one of Reg's designs, so he can better tell the pros and cons of using it. The reasons why I did not use gt2 belts are that
On the other hand, with fishing line no change was necessary, it took about 10 minutes to mount everything after printing the two plastic supports I needed, at nearly zero cost.
- I should have changed considerably the design of my printer, in particular I should have used some geared system to increase the step resolution along Z;
- I should have bought belt and pulley;
- I had already fishing line here.
Actually I don't understand why people don't try as much as possible to use fishing line instead of belts: it is so convenient and cheap...
Re: Printing quality: pursuing perfection November 22, 2014 05:22AM |
Re: Printing quality: pursuing perfection November 22, 2014 07:06AM |
fabrice974
i'm working on a gt2 z belt system
Re: Printing quality: pursuing perfection November 29, 2014 09:07PM |
How about driving a pulley with a second belt?Quote
fabrice974
Re: Printing quality: pursuing perfection November 29, 2014 09:09PM |
BackEMF
That's an interesting idea that i sure want to try.
looks like that coupling does something similair, but then with a plastic 'spacer'. It would eventually be printable aswell.
And what about setting the Z drive shaft in bearings? this way the shaft cant wobble, but the coupling has to be flexible to compensate for misalignment.
Re: Printing quality: pursuing perfection November 29, 2014 10:47PM |
regpye
One from the motor to a double timing wheel, and from the second timing wheel a belt to position the Z axis.
