Re: New "old" SmartRap Build February 08, 2015 02:25AM |
If you ever get a heated bed, try sugar and water method, it is the very best of all of them.Quote
prpickett
Had success with both glue stick and wood glue thinned with 2x water. Glue stick worked too well, I thought I was going to break something trying to get the part off. Now that I have 2 glass plates set up with the PVA glue, I may stick with that rather than adding a heated bed. The hot-end is the biggest problem right now. I haven't had success with anything above a speed of 30. I still need to do a temp. calibration print but 205 C seems to be the sweet spot with my current filament. I've been printing these at 75% ( [www.thingiverse.com] ) based upon some requests from my wife's 5th grade class. Come out pretty well except for the strings. I just cut them off since even when they come out good, one strum and they snap.
Re: New "old" SmartRap Build February 08, 2015 01:18PM |
Re: New "old" SmartRap Build February 08, 2015 02:03PM |
Re: New "old" SmartRap Build February 12, 2015 02:53AM |
Re: New "old" SmartRap Build February 12, 2015 07:27AM |
Re: New "old" SmartRap Build March 07, 2015 05:19PM |
Re: New "old" SmartRap Build March 07, 2015 06:23PM |
prpickett
Adding a heated bed to the printer currently. Also working on modifying the carriages for Reg's bushings. I seem to remember reading that they worked better if you left them connected so I need to move the mounts closer. May also try printing 10mm bushings for the Z axis since I have 10mm rod. That would allow me to use the current z rods for the x-axis and increase my build area. I'm currently 190x120x180. I may put the z-rods on a platform since the new bed will raise the y-axis a bit and there is already a cm or so at the bottom I can't use. Also ended up leaking PLA from my nozzle. Don't think I had assembled correctly (Didn't tighten after heating). Regarding the heatbed, I understand that I need to put an insulating material between the PCB and the mounting surface (probably going to use thin MDF since I have some). I've read that cork or even cardboard will work under the PCB, any thoughts on what is effective, readily available, and inexpensive? Also, do you just put the thermister through the center hole and tape or do most folks put some type of sealant in the hole?
