Wanting to go back to servo setup January 07, 2015 05:47PM |
Re: Wanting to go back to servo setup January 07, 2015 08:40PM |
Re: Wanting to go back to servo setup January 08, 2015 07:19AM |
Re: Wanting to go back to servo setup January 08, 2015 01:15PM |
Re: Wanting to go back to servo setup January 08, 2015 03:21PM |
Re: Wanting to go back to servo setup January 08, 2015 09:09PM |
Re: Wanting to go back to servo setup January 09, 2015 01:34AM |
griffinaeronautics
I do not like the amount of play in the current servoless setup on the smartrap. I feel that the servo setup will allow for the hotend to have way less play. I also have odd endstops and I want to be able to use them. Does anyone have a file for a servo setup with GT2 belt and for the jhead lite v2.1? Or any suggestions that would help my process?
Re: Wanting to go back to servo setup January 09, 2015 04:19AM |
Re: Wanting to go back to servo setup January 09, 2015 05:18AM |
ldanut
I don't use autoleveling. It seems it creates more problem than it solves. I can tune bed leveling manually and I just do a single point probe to do the Z height check. No problem since then and I didn't have to worry about recalibrating in months. I plan to use a Hall sensor probe instead of microswitch for better accuracy. I need some time to design it. There is another good aspect of hinged print head. In cases when you have plastic resedue on print and head bumb into it it can move up and avoid crashing. I saw this couple of times and I like it.
Re: Wanting to go back to servo setup January 10, 2015 05:10PM |
knife-edge
So I will go with the inductive sensor. Is it in config h? And do I put it so that it is above the tip of the hotend? I'm confused as how to set it up.
