My SMartRapCore Build April 19, 2015 11:47PM |
Re: My SMartRapCore Build April 23, 2015 12:56AM |
Re: My SMartRapCore Build April 23, 2015 10:18AM |
Re: My SMartRapCore Build April 23, 2015 11:00AM |
Re: My SMartRapCore Build April 23, 2015 11:14AM |
Re: My SMartRapCore Build April 23, 2015 12:21PM |
Re: My SMartRapCore Build April 23, 2015 01:45PM |
Re: My SMartRapCore Build April 23, 2015 02:05PM |
rcjoseb
Thanks for the compliments. Each z axis will have its own motor and GT2 belt.
The single belt/motor/threaded rod sounds like a good idea as well. Now you have me thinking too! Another way it can be done is to use a dual shaft Nema 17 motor. Attach a 5mm threaded rod or 5mm drill rod to each side of the shaft with a coupler and the ends of the rods to a pulley/belt.
Closed GT2 belt on ebay.
[www.ebay.com]
Here's an 8mm bore 20t pulley if you want to go with 8mm rods
[www.ebay.com]
Here's a dual shaft Nema17
[www.ebay.com]
Another way is to do a direct drive. Print the gears like you would for a wades extruder, one for the motor and the other for the shaft.
Re: My SMartRapCore Build April 23, 2015 02:38PM |
Re: My SMartRapCore Build April 27, 2015 12:03AM |
Re: My SMartRapCore Build April 27, 2015 01:41AM |
Re: My SMartRapCore Build April 27, 2015 09:45AM |
Re: My SMartRapCore Build April 28, 2015 11:53PM |
Re: My SMartRapCore Build April 29, 2015 11:23PM |
Re: My SMartRapCore Build April 30, 2015 03:33PM |
Re: My SMartRapCore Build April 30, 2015 05:38PM |
Re: My SMartRapCore Build April 30, 2015 10:50PM |
Re: My SMartRapCore Build April 30, 2015 11:13PM |
Re: My SMartRapCore Build May 01, 2015 03:18AM |
Re: My SMartRapCore Build May 06, 2015 05:56PM |
Re: My SMartRapCore Build May 14, 2015 12:20AM |
Re: My SMartRapCore Build May 14, 2015 06:07AM |
Re: My SMartRapCore Build May 14, 2015 10:08AM |
Re: My SMartRapCore Build May 14, 2015 10:21AM |
Re: My SMartRapCore Build May 14, 2015 11:16AM |
Re: My SMartRapCore Build May 14, 2015 01:15PM |
Re: My SMartRapCore Build May 26, 2015 03:48PM |
Re: My SMartRapCore Build May 27, 2015 03:24AM |
Re: My SMartRapCore Build May 27, 2015 10:46AM |
