Smartcore build log and pre-build questions April 26, 2015 03:35AM |
Re: Smartcore build log and pre-build questions April 26, 2015 10:40AM |
Re: Smartcore build log and pre-build questions April 26, 2015 10:52AM |
Re: Smartcore build log and pre-build questions April 26, 2015 11:17AM |
Re: Smartcore build log and pre-build questions April 26, 2015 05:23PM |
Re: Smartcore build log and pre-build questions April 26, 2015 11:53PM |
Re: Smartcore build log and pre-build questions April 27, 2015 04:42AM |
Re: Smartcore build log and pre-build questions April 27, 2015 08:24AM |
Re: Smartcore build log and pre-build questions April 27, 2015 05:50PM |
Re: Smartcore build log and pre-build questions April 27, 2015 11:21PM |
Re: Smartcore build log and pre-build questions May 01, 2015 12:51PM |
Re: Smartcore build log and pre-build questions May 01, 2015 01:03PM |
Re: Smartcore build log and pre-build questions May 01, 2015 01:11PM |
Re: Smartcore build log and pre-build questions May 01, 2015 03:11PM |
Re: Smartcore build log and pre-build questions May 01, 2015 04:02PM |
Re: Smartcore build log and pre-build questions May 02, 2015 01:50PM |
Re: Smartcore build log and pre-build questions May 07, 2015 08:23AM |
Re: Smartcore build log and pre-build questions May 07, 2015 09:09AM |
Re: Smartcore build log and pre-build questions May 07, 2015 11:03AM |
Re: Smartcore build log and pre-build questions May 07, 2015 02:03PM |
For noise rubber feet helped mine for sure, as well as vref adjustments, I thought I was in a sweet spot and it was loud, motors were hot all the time, turned v-ref down to .25v for mine and it quieted right up, motors never get "hot" anymore either. I am also contemplating an enclosure, but have bigger fish to fry, I think I am going v-slot on the rails
Re: Smartcore build log and pre-build questions May 07, 2015 05:17PM |
Re: Smartcore build log and pre-build questions May 07, 2015 05:57PM |
Re: Smartcore build log and pre-build questions May 07, 2015 07:20PM |
Re: Smartcore build log and pre-build questions May 08, 2015 12:59AM |
Re: Smartcore build log and pre-build questions May 08, 2015 04:13AM |
Re: Smartcore build log and pre-build questions May 12, 2015 07:22AM |
#define INVERT_X_DIR true #define INVERT_Y_DIR truemake my printer run in the opposite directions. I could change this by setting endstops to MAX but this seems really strange. If I set the invert XY directions false, I get repetier host treating manual controls all in the right direction but GCode runs the opposite direction.
Re: Smartcore build log and pre-build questions May 12, 2015 09:00AM |
I can't believe (although now have to) that this made such a difference. The massive Z compensation values were related to the bed lowering by 8mm at each point probed when I had that mysterious issue that resolved itself just as mysteriously. For note, the Z & E motors' wiring is still the original way around! I'm now using #define INVERT_X_DIR true #define INVERT_Y_DIR trueas intended.
Re: Smartcore build log and pre-build questions June 04, 2015 05:39PM |
Re: Smartcore build log and pre-build questions August 05, 2015 06:05PM |
Re: Smartcore build log and pre-build questions September 16, 2015 02:47AM |
