SmartRapCore dual Z axis with 2 motors issue May 30, 2015 08:30PM |
Re: SmartRapCore dual Z axis with 2 motors issue May 31, 2015 09:49AM |
Re: SmartRapCore dual Z axis with 2 motors issue May 31, 2015 11:55AM |
Re: SmartRapCore dual Z axis with 2 motors issue May 31, 2015 08:20PM |
Re: SmartRapCore dual Z axis with 2 motors issue June 01, 2015 03:46PM |
rcjoseb
I am using an NPN NO inductive sensor and after watching Tom's Sandlerer's video, listening carefully to what he said and some testing, I figured out that my LM7805 was wired incorrectly. When using an NPN NO inductive sensor, only connect the output pin of the LM7805 to the signal pin on the y-min endstop header. If you attach both signal pin and a ground, it will either cause the RAMPS to fail or it will never recognize the voltage drop to 0 which is how that inductive sensor works.
Re: SmartRapCore dual Z axis with 2 motors issue June 01, 2015 04:39PM |
Re: SmartRapCore dual Z axis with 2 motors issue June 04, 2015 12:54PM |
