mandrav's SmartCore build June 19, 2015 03:27PM |
) and settled on using cheap aluminum extrusions (the plain square type).
(thanks Mike!).
. This made a world of difference for me. And since I mentioned the Z axis, I should give credits also to Jerry because I 'm using his design for the threaded rod driven Z axis (thanks Jerry!).
Re: mandrav's SmartCore build June 19, 2015 04:07PM |
Re: mandrav's SmartCore build June 22, 2015 10:28AM |
Re: mandrav's SmartCore build June 22, 2015 12:23PM |
Re: mandrav's SmartCore build June 22, 2015 07:54PM |
Re: mandrav's SmartCore build June 23, 2015 06:09AM |
smerrett79
Yiannis, please could you share your print cooling fan setup? thanks
(I 'm not sure how I can provide links to them directly).|
Re: mandrav's SmartCore build June 28, 2015 05:32AM |
Re: mandrav's SmartCore build June 28, 2015 09:23AM |
Re: mandrav's SmartCore build June 28, 2015 11:10AM |
Re: mandrav's SmartCore build June 29, 2015 06:18PM |
Re: mandrav's SmartCore build June 30, 2015 05:12AM |
smerrett79
@Mandrav, thank you. Not sure I'll get those files to work for my setup (E3D Lite6) but I'm going to try something else first. Your prints look amazing! Please could you give us more detail on the bushings/rods you use?
Re: mandrav's SmartCore build July 01, 2015 06:20AM |
Re: mandrav's SmartCore build July 01, 2015 01:33PM |
Re: mandrav's SmartCore build July 02, 2015 04:45AM |
Other bushings|
Re: mandrav's SmartCore build July 02, 2015 08:00AM |
CeledaBcn
Hi
What parameters you changed to use this bushings?
I'm planing about use this ones Bushings
I'm a bit losed with the code
Edit: Maybe can use this onesOther bushings
Re: mandrav's SmartCore build August 18, 2015 07:57AM |
Re: mandrav's SmartCore build August 18, 2015 04:32PM |
Re: mandrav's SmartCore build August 18, 2015 04:48PM |
Re: mandrav's SmartCore build August 19, 2015 09:05AM |
Re: mandrav's SmartCore build August 19, 2015 11:11AM |
Re: mandrav's SmartCore build August 19, 2015 03:55PM |
Re: mandrav's SmartCore build August 19, 2015 04:08PM |
MichaelBrock
Mandrav, have the two separate z-axis motors been working well for you? It is my plan to add a second z-axis carriage and saw some discussion that running two separate motors makes it difficult to keep them in sync.
Re: mandrav's SmartCore build August 20, 2015 02:13AM |
MichaelBrock
Michael
Re: mandrav's SmartCore build August 20, 2015 02:17AM |
mandrav
In my case I need the 2nd Z axis because with a single one the bed is not stable enough for me. I believe it needs a better Z carriage but it was easier for me to just add a second motor that I had lying around
I reused the rods as they were. No sanding/polishing. I can measure dimensions with calipers but it will have to wait for the weekend because I 'm on a deadline at work and I barely even go home these days...
Re: mandrav's SmartCore build September 03, 2015 06:38PM |
Re: mandrav's SmartCore build September 03, 2015 07:46PM |
Re: mandrav's SmartCore build September 04, 2015 04:25AM |
smerrett79
Yiannis, please could you point to the lines in the code you edited to make the head accept the bushings and describe if you went for interference fit between bushing and head hole etc? Thank you
Re: mandrav's SmartCore build September 04, 2015 05:26PM |
Re: mandrav's SmartCore build September 11, 2015 05:01AM |
Re: mandrav's SmartCore build September 17, 2015 12:29PM |
