mandrav's SmartCore build
Posted by mandrav
Re: mandrav's SmartCore build
September 18, 2015 09:59AM
@jjazzyj: great work!
@eviltoy: I will have a look at my files and publish it, if found smiling smiley
September 18, 2015 12:40PM
@eviltoy:
I believe I have the files mandrav used and you are now looking for:
http://www.thingiverse.com/thing:873622
http://www.thingiverse.com/thing:874283
I had them in my collections on Thingiverse and based my design on.
September 18, 2015 03:16PM
@eviltoy: thanks for the help! the first thing you linked is indeed what I used.
September 18, 2015 03:17PM
eviltoy
Do you perhaps have a link to the files you used for you corner connectors and stablisers at the bottom please?
Yup, just found them!
Uploaded here smiling smiley
September 21, 2015 11:26AM
@mandrav
I just posted the part to Thingiverse with some install instructions:
http://www.thingiverse.com/thing:1026857
Edited 1 time(s). Last edit at 09/21/2015 11:26AM by jjazzyj.
September 22, 2015 03:54AM
Nice smiling smiley
December 07, 2015 03:20AM
Only saw this now. Thanks so much dude!
February 05, 2016 01:53PM
mandrav
Both bushing types you linked should work just fine.
For using them you have two options:
a) edit the jscad file to change the hole dimensions for 'head' and 'slide_y' so that the bushings you choose fit, or
b) you can search thingiverse for 'bushing adapter'. With these you will fit your bushings inside the adapter and use the adapter in place of the lm8uu/lm6uu you would otherwise use.
I finally went with option (a). But I first had tried option (b) and that didn't go too well for me... YMMV...
HTH.
If i change the parameter in _XYlmDiam variables for 8 mm will work?
Or maybe create another like "B8" for Bushings 8mm xD
I really like the parameterizable that is openscad a openjscad... but i don't know all of it xD
