Smartfriendz - please fix your repo July 13, 2015 06:20PM |
Re: Smartfriendz - please fix your repo July 14, 2015 03:40AM |
Re: Smartfriendz - please fix your repo July 14, 2015 01:15PM |
Re: Smartfriendz - please fix your repo July 14, 2015 04:42PM |
Re: Smartfriendz - please fix your repo July 14, 2015 05:05PM |
Re: Smartfriendz - please fix your repo July 14, 2015 11:54PM |
rcjoseb
Once the entire printed parts plate appears:
1. Click on get stl.
2. Once the stl file is downloaded to your pc give it a name like Master plate.
3. Open it up in Cura.
4. In Cura right click on the part and select separate object into parts and give it some time
5. Once done delete parts that you do not want or delete parts to fit on the plate. For example keep only the motor mounts.
6. Save it as a plate. For example save it as motor mounts.
7. Reload the master stl and repeat the process until you have stl files with parts you want
Re: Smartfriendz - please fix your repo July 15, 2015 01:00AM |
Re: Smartfriendz - please fix your repo July 18, 2015 10:16AM |
