V1.2x issues July 19, 2015 11:23AM |
Re: V1.2x issues July 19, 2015 12:57PM |
Re: V1.2x issues July 19, 2015 01:24PM |
Re: V1.2x issues July 20, 2015 02:16PM |
Re: V1.2x issues July 20, 2015 02:20PM |
Re: V1.2x issues July 20, 2015 06:12PM |
smerrett79
Some people use Cura to divide stl plates. I use the cut function in netfab which lets you save the sections you cut the plate into as stls. Is that what you're struggling with?
Re: V1.2x issues July 21, 2015 03:59AM |
Re: V1.2x issues July 21, 2015 09:24AM |
Re: V1.2x issues July 23, 2015 07:03PM |
Re: V1.2x issues July 29, 2015 11:49AM |
rcjoseb
If you would like to use Cura to separate out the parts: It's a little tedious but it works.
Once the entire printed parts plate appears in OpenJSCad:
1. Click on get stl.
2. Once the stl file is downloaded to your pc give it a name like Master plate.
3. Open it up in Cura.
4. In Cura right click on the part and select separate object into parts and give it some time
5. Once done delete parts that you do not want or delete parts to fit on the plate. For example keep only the motor mounts.
6. Save it as a plate. For example save it as motor mounts.
7. Reload the master stl and repeat the process until you have stl files with parts you want
Re: V1.2x issues August 01, 2015 05:06PM |
MichaelBrock
I tried using Cura but I do not have the right-click option to separate the plate for some reason.
I have found someone that will print the parts for my printer (at a price of course) and he will print the "latest version" but now I'm worried that the latest stls will have critical errors in them and getting things re-printed is going to be a pain without access to a printer.
Are updates and issues like these discussed more frequently in the French language forum? Is there a formal listing of what the changes are between versions?
Re: V1.2x issues August 01, 2015 05:49PM |
Re: V1.2x issues August 01, 2015 06:00PM |
Re: V1.2x issues August 01, 2015 06:43PM |
smerrett79
I haven't had a response about the 1.4 but there is support for these printers - I've had replies from Serge before and you'll see him on these forums. I have a 1.01 (I think) printing really well compared to my first QUBD two up. Just reprinted parts for it and have made the leap to ABS. For info, I used the openjscad printer plate and had 18mm mdf and 8mm dia rods all round.
Re: V1.2x issues August 02, 2015 02:57AM |
TypeError: Object doesn't support property or method 'join' Stack trace: TypeError: Object doesn't support property or method 'join' at CSG.Polygon.Shared.prototype.getHash (http://openjscad.org/csg.js:2944:13) at CSG.fuzzyCSGFactory.prototype.getPolygonShared (http://openjscad.org/csg.js:4615:13) at Anonymous function (http://openjscad.org/csg.js:689:21) at Array.prototype.map (native code) at CSG.prototype.reTesselated (http://openjscad.org/csg.js:687:17) at CSG.prototype.union (http://openjscad.org/csg.js:240:13) at union (http://openjscad.org/openscad.js:329:7) at motorXY (blob:9778A84D-D4BB-41BC-8063-E2D804F9B194:534:5) at main (blob:9778A84D-D4BB-41BC-8063-E2D804F9B194:1416:9) at OpenJsCad.runMainInWorker (http://openjscad.org/openjscad.js:580:5)
Re: V1.2x issues August 02, 2015 08:09AM |
Re: V1.2x issues August 02, 2015 10:24PM |
3DFreezeMe
Is anyone able to get the v1.2.x versions working ok on the openjscad.org site? I get errors when rendering most of the different views when selecting them in the 'what to show' dropdown menu.
Re: V1.2x issues August 03, 2015 07:17AM |
3DFreezeMe
The error:
Re: V1.2x issues August 03, 2015 08:24AM |
MichaelBrock
3DFreezeMe
The error:
I just tested this, in firefox, with the copy of v.1.2.x that I had downloaded a few weeks ago and it did render at the [create.youmagine.com] site as suggested. I have attached that copy of the v1.2.x that worked.
Re: V1.2x issues August 03, 2015 08:52AM |
Re: V1.2x issues August 03, 2015 09:49AM |
MichaelBrock
Go to [create.youmagine.com] . At the bottom of the page you'll see an area outlined in dashed lines. With your mouse, drag the downloaded .jscad file into that area. The page will load the jscad file and render it (not sure if it renders it automatically or if you have to click a button for it)
Re: V1.2x issues August 03, 2015 02:45PM |
Re: V1.2x issues August 03, 2015 02:48PM |
Re: V1.2x issues August 03, 2015 03:15PM |
Re: V1.2x issues August 03, 2015 04:31PM |
Re: V1.2x issues August 03, 2015 04:44PM |
Re: V1.2x issues August 03, 2015 04:47PM |
Re: V1.2x issues August 03, 2015 04:49PM |
Re: V1.2x issues August 03, 2015 04:52PM |
