SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) September 27, 2015 12:45PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) September 27, 2015 02:31PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) September 27, 2015 03:09PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) September 27, 2015 05:53PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) September 28, 2015 12:49PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) September 28, 2015 05:46PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) September 30, 2015 01:31AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 02, 2015 07:06PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 03, 2015 03:09AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 03, 2015 11:12AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 03, 2015 01:25PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 04, 2015 11:44AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 15, 2015 04:00AM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 15, 2015 04:07AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) October 15, 2015 05:19AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) April 23, 2016 03:30PM |
smartfriendz
are you sure the perpendicular problem is more with an HBOT system ? I tought it was not so important with a coreXY. Well, from our tests, we didn't noticed any problems with non perpendicular lines on coreXY .
pythagoras: type this into python or use a calculator: pow(pow(20, 2) + pow(70,2), 0.5)
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 22, 2016 08:43AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 22, 2016 04:43PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 22, 2016 07:39PM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 23, 2016 08:25AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 23, 2016 09:39AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 24, 2016 09:13AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 25, 2016 02:53AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 27, 2016 11:08AM |
lkcl
smartfriendz
it's absolutely critical. Wurstnase is absolutely right.
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 28, 2016 05:36AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 28, 2016 05:41AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 28, 2016 06:11AM |
3DFreezeMe
Your idea of adding this in the front section will be giving back some of the lost build volume in the X direction. Ikcl did exactly this in his Sandwich200v1 design, as his first screenshot posted above shows.
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 28, 2016 06:27AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 28, 2016 06:55AM |
Re: SmartrapCore HK13 (8mm rods - 13mm square Alu tubes) August 28, 2016 05:43PM |
