Anyone still use the original smartrap?
Posted by duranza
January 26, 2016 04:54PM
I have been away for a while and wanted to see if there are any still using the original smartrap.
Re: Anyone still use the original smartrap?
January 29, 2016 05:08AM
Just built one. Cost under 200 and prints reliably. Just not real fast.
February 01, 2016 03:45PM
I tore mine down and built a Funbot M8 with the parts.
February 02, 2016 11:13PM
I made a new z probe with a magnetic retract that fits the smartrap and could be adapted to others. I can post it if interested.
February 03, 2016 09:18AM
sounds interresting ! (Even if I am on a smartrapcore !)
February 04, 2016 04:10PM
February 05, 2016 03:46AM
interrsteing ! Do you use a microswitch, a hall effect sensor or an optic sensor on top ?
February 05, 2016 02:12PM
I have an optical switch, but can be used with a hall sensor too
February 07, 2016 07:44AM
I do, although with some modifications on the extruder and Z axis.
February 07, 2016 09:02PM
Here are the files. You would need an 1/8 diameter steel rod 43mm in length and a 3/16 wide x 1/16 thick bar magnet. A spring or rubber band to retract the slider. And of course an optical sensor
Edited 1 time(s). Last edit at 02/09/2016 12:14AM by duranza.
open | download - slide stop v3.STL (6.7 KB)
open | download - new y base with slide stop.stl (476.3 KB)
February 08, 2016 12:44AM
Thanks for the files! I don't see how you make the rod drop when starting probing?
February 09, 2016 12:12AM
it uses a spring on the back of the slide. It moves the magnet forward when it homes out. I'll make another video tomorrow while triggering it by hand to show how it works better.
February 09, 2016 02:32AM
Ho ! Ok! I see now! Similar to that one [www.thingiverse.com]!
Very clever... I like it smiling smiley
February 09, 2016 04:47PM
Yes. Just like that one lol I wish I had seen this before. I made mine from another one that Idanut had made with a servo.
