Smartrapcore Alu (Speeds / Config) May 30, 2016 10:13PM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {160,160,160,290} // GT2 Belts with 1/32 step count, MK8 extruder
#define DEFAULT_MAX_FEEDRATE {500, 500, 70, 50} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {7000,7000,2000,10000} // X, Y, Z, E maximum start speed for accelerated moves.
#define DEFAULT_ACCELERATION 900 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 10.0 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Smartrapcore Alu (Speeds / Config) June 01, 2016 04:25AM |
