Offset from HomingOrigin June 12, 2016 02:06PM |
Re: Offset from HomingOrigin June 14, 2016 06:05AM |
// The position of the homing switches //#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used //#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: // For deltabots this means top and center of the Cartesian print volume. #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 0 //#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing.
// Travel limits after homing #define X_MAX_POS 190 #define X_MIN_POS 0 #define Y_MAX_POS 180 #define Y_MIN_POS 0 #define Z_MAX_POS 160 #define Z_MIN_POS 0then it will not move below 0,0 unless it receives a home command.
Re: Offset from HomingOrigin June 23, 2016 12:13PM |
Re: Offset from HomingOrigin June 23, 2016 12:51PM |
Re: Offset from HomingOrigin June 23, 2016 01:05PM |
Re: Offset from HomingOrigin June 23, 2016 01:13PM |
Re: Offset from HomingOrigin June 23, 2016 01:19PM |
DjDemonD
@pdbeal setting a home offset like this and then making sure your travel limits are correct will not limit your travel across the bed unless that's a limitation in marlin 1.0.x in all 1.1.0 RC versions it works just fine
My offsets are x-7 y-39 and my travel limits are x0-280 y0-200 z-3 - 170 on my enlarged machine.
Re: Offset from HomingOrigin June 23, 2016 02:49PM |
