E3D V6 Hotend Bowden Version
Posted by Sompy
June 27, 2016 06:44AM
Hallo
Will a E3D V6 Hotend fix in the Hotend-Mount that is original on the Smartrapcore ALU ?
For me the " Bowden Version " of the E3D V6 looks much bigger !
Best Regards
Re: E3D V6 Hotend Bowden Version
June 27, 2016 04:56PM
Depends if your talking 1.75 filament or 3.0 filament.
E3D V6 1.75 Universal (Direct or Bowden) drawing
E3D V6 3.0 Direct drawing
E3D V6 3.0 Bowden drawing
According to the wiki drawings, the E3D V6 1.75 direct or bowden are the same physical size at 62.3mm. The E3D V6 3.0 direct is also 62.3, but the E3D V6 3.0 Bowden is shown as 65.6mm with a 1.6mm bowden clip. That being said, it only appears as the top side of the mounting ring is larger on the bowden, so there probably isn't any height difference to the nozzle using the Smartrapcore ALU hotend mount (assuming you got the original bowden mount and not his new direct drive piece)
I have the E3D V6 on my Smartrapcore ALU, but I didn't like how close the X axis homing switch was to the heatbed on the first few layers of printing, so I modified the bracket to lower my hotend slightly.
June 28, 2016 06:49AM
My solution was to relocate the x endstop to the left y slide. But lowering the bracket would probably make it a bit more stable. I found 1.75mm v6 fits the bracket perfectly.
Edited 1 time(s). Last edit at 06/28/2016 04:42PM by DjDemonD.
Simon.
[www.precisionpiezo.co.uk] Accurate, repeatable, versatile z-probe plus piezo discs, endstop cables, pt100, 50w heaters. PT1000 cartridge sensors plug straight into duet boards and others.
Published:Inventions
