So I have added two revised motor mounts to the listing above for the linear rail conversion. They have a few features that were relevant to smooth rods removed, and have the motors positioned 1.5mm towards the centre of the printer to correct the belt geometry to pretty damn straight between the y-slides and motors. It is assumed you are using 608zz bearings or other bearing of the same diameter, and 16 tooth pulleys to get the correct geometry. Please attach the motors with plain hex head m3 bolts (not allen key cap headed screws) and do this BEFORE you attach the mounts to the printer or you will be driven mad by how fiddly it is.
Edited 1 time(s). Last edit at 07/01/2017 05:02AM by DjDemonD.
Simon Khoury
Published:Inventions
