I am building my first 3D printer - SmartRapCore XY - highly modified (started bigger than plans)
motion seems to be pretty accurate - when told to move 10CM in any direction it looks pretty close but haven't calibrated the steps yet
I have a photo-sensor on X and Y directions that will halt motion and Zero each direction when I click HOME in either direction.
I want to do auto leveling of the bed and bought the probe suggested online. It seems to be functioning as it will stop the motion if I put metal under the probe.... but I don't have a metal bed (plywood with glass build plate) Foil tape on the glass will be sensed. Do I have to put foil under the entire piece of glass or just under a few spots for the auto leveling to work and if I home the Z axis how to I make it go to a spot before homing so it doesn't raise the bed with no foil and hit glass on the nozzle??
I don't have the rest of the wiring hooked up yet as I am still figuring out where I want my cable runs to go so they are out of the way, but I was wondering if there is some wiring that MUST be hooked up before everything else will work?
Dmac257
