Re: Teile f
June 12, 2008 09:55AM
Max,
Fine, I am not the dumb then to pay 1200 Euros instead of 400 :-))
Anyway, PIC programmer is not necessary if you drive with Arduino. I am using PIC at the moment, but I think arduino is a better solution especially for motor driving. PIC shakes the frame a lot as I heard Arduino is smoother. I have not tried yet though...
Adam
Re: Teile f
June 12, 2008 10:16AM
Hi Adam,
I
Re: Teile f
June 12, 2008 01:28PM
Max,
Good idea, you may want to check out this thread: [forums.reprap.org]
I was thinking about the same thing but eventually got stuck with the original design for which I had the documentation on wiki. So, I was sure I could finish my machine :-))
But honestly I am looking forward to your experiments because it sounds very interesting!
Look, "Black magic" is way more simple than setting up a properly working mechanics, but you may want to ask CNC geeks about this. I had no knowledge about electronics before (I mean NO!!!) and now through this project I learned a lot. I still can not design electronics very well, but not interested either... All in all, you do not have to be afraid of this at all!
Adam
VDX
Re: Teile f
June 12, 2008 02:45PM
Hi Max,
... wenn du Schrittmotore suchst, ich habe noch ein paar Typen bei mir rumliegen:
Die beiden Gro
open | download - Stepper-Mitte_kl.jpg (145.3 KB)
Re: Teile f
June 13, 2008 07:52AM
Wieviel w
Re: Teile f
June 13, 2008 08:17AM
Arduino gibt derzeit in Deutschland nur bei [www.segor.de] Genaue Bezeichnung: "Arduino Diecimila Fertigboard mit Usb"
Falls du ohnehin vorhattest bei RRRF zu bestellen, kannst es da mitbestellen.
Rollen und Riemen z. B bei [conrad.de] , da ist aber die Auswahl nicht so toll, besser ist die z.B. bei [maedler.de]
VDX
Re: Teile f
June 13, 2008 09:30AM
Hi Max,
... ich dachte da an 5 Euro pro Motor plus Porto - also 25 bis 30 Euro.
Viktor
Re: Teile f
June 14, 2008 05:41AM
Hi Viktor,
alles klar eint
Re: Teile f
June 14, 2008 09:26AM
Hallo!
Ich komme aus Hannover, bin Maschinenbau-Student im 2. Semester und verfolge RepRap nun schon eine ganze Weile.
Ein richtiger Reprap ist mir im Moment leider noch etwas zu teuer, deswegen w
Re: Teile f
June 14, 2008 10:08AM
Hi Tuchs!
Das siehst du richtig, der Extruderkopf wiegt nicht viel und
Re: Teile f
June 14, 2008 11:40AM
Pollin hat auch einen Bausatz:
[www.pollin.de]
Mit L298, aber ohne L297. Sieht wie die "Original"-RepRap-Treiberplatine nicht allzu anspruchsvoll zu l
Re: Teile f
June 14, 2008 02:18PM
Ich glaube, wenn du die Schrittmotoren mit dem Arduino ansteueren willst, brauchst du beide Chips, ein Computer hat genug Rechenpower und ports, da knn man den Controller-Chip locker weglassen, aber beim Arduino ist das alles etwas begrenzter --> Das w
VDX
Re: Teile f
June 14, 2008 03:41PM
... nun wird's etwas knapp mit dem Motoren - Marcel hatte auch schon sein Interesse angemeldet.
Da die Motoren unterschiedliche Werte (Nennspannung -Strom und Spulenwiderstand), aber
Re: Teile f
June 14, 2008 06:55PM
Hallo,
Die 24V-Motoren sind f
Edited 1 time(s). Last edit at 06/15/2008 01:38PM by Tuchs.
Re: Teile f
June 17, 2008 08:56PM
Hallo,
tut mir leid wenn ich etwas ungeduldig bin, aber wie sieht es denn jetzt mit den Motoren aus?
MfG Tuchs
VDX
Re: Teile f
June 18, 2008 03:26AM
Hi Tuchs,
... sorry - hab deinen 'Edit' verpa
VDX
Re: Teile f
June 18, 2008 03:34PM
Update:
... die 4 Hellblauen Motoren sind weg ...
Viktor
Re: Teile f
June 18, 2008 07:04PM
Viktor Wrote:
> Und dann noch die kleinen 4-eckigen 42-er Motore
> (schw
VDX
Re: Teile f
June 19, 2008 03:22AM
Hi Tuchs,
... ich schaue heute Abend, wenn ich wieder im Keller bin, nach den genauen Daten.
Hier erstmal vorab: die 42-er Motore sind in der Mehrzahl 100-Schritt-Unipolarmotore aus alten AEG-Typenrad-Schreibmaschinen, aber auch ein paar 200-Schritt-Bipolarmotoren von Berger-Lahr oder aus alten Festplatten. Spannung und Strom mu
Re: Teile f
June 19, 2008 11:08AM
Hallo,
48 Schritte h
VDX
Re: Teile f
June 19, 2008 04:47PM
Hi Tuchs,
die drei schwarzen kannst du f
VDX
Re: Teile f
June 23, 2008 03:26PM
Update:
... die bestellten Motoren sind heute Vormittag per Post rausgegangen, sagt evtl. Bescheid, wenn sie ankommen.
Jetzt sind nur noch 3x 1,53V/3A-Motoren, 6x 24V/0,18A die schw
Re: Teile f
June 24, 2008 05:26PM
Meine Motoren sind, wie per PN geschrieben, heute gekommen.
Ich hoffe bald einige Schrittmotortreiber zusammenzukriegen, Donnerstag werden wahrscheinlich erste Holzleisten f
Re: Teile f
June 25, 2008 03:58AM
Moin,
Motoren sind gestern angekommen. Alles klar :-)
Danke nochmal!
Gru
VDX
Re: Teile f
June 25, 2008 02:18PM
... dann viel Gl
Re: Teile f
August 18, 2008 11:15AM
hey smiling smiley ich bin neu hier und hab den Ehrgeiz mir auch eine RepRap aufzubauen smiling smiley... Ich hab bereits erfahrung mit Mikroelektronik und nehm mir jetzt ersteinmal den Aufbau der elektronik vor etc...
Ich wollte fragen, ob es bei der Arduino firmware besonderes zu beachten gilt, wen ich Treiber f
VDX
Re: Teile f
August 18, 2008 03:07PM
Hi Tom,
im Prinzip kannst du jeden Treiber dranh
Re: Teile f
August 27, 2008 06:47AM
so... der Anfang ist getan.. ich hab jezt einen Arduino bei mir zuhause rumstehen... ich
sid
Re: Teile f
August 28, 2008 02:00PM
Hi Viktor, sei so gut und schau mal nach den Nema17 Motoren, ob da drei identische bei sind (am liebsten Bipolare) mit 1,8
VDX
Re: Teile f
August 28, 2008 03:25PM
Hi sid,
... die Nema17 sind knapp 42x42 mm gro
Edited 1 time(s). Last edit at 08/28/2008 03:29PM by Viktor.
Sorry, you do not have permission to post/reply in this forum.
