Re: Reprap Host beta July 16, 2010 01:08PM |
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org | ![]() |
Re: Reprap Host beta July 16, 2010 01:12PM |
Re: Reprap Host beta July 16, 2010 01:14PM |
Re: Reprap Host beta July 16, 2010 01:26PM |
Re: Reprap Host beta July 16, 2010 01:42PM |
$ skeinforge_application/skeinforge.py test.stl File test.stl is being chain exported. Carve procedure took 1 second. Preface procedure took 0 seconds. Inset procedure took 1 second. Fill procedure took 2 seconds. Speed procedure took 0 seconds. Temperature procedure took 0 seconds. Raft procedure took 2 seconds. Chamber procedure took 0 seconds. Jitter procedure took 0 seconds. Clip procedure took 2 seconds. Cool procedure took 0 seconds. The lower left corner of the behold window is at -5.796, -2.952 The upper right corner of the behold window is at 66.276, 43.272 Statistics are being generated for the file test_export.gcode Cost Machine time cost is 0.21$. Material cost is 0.02$. Total cost is 0.22$. Extent X axis extrusion starts at -6 mm and ends at 67 mm, for a width of 72 mm. Y axis extrusion starts at -3 mm and ends at 44 mm, for a depth of 46 mm. Z axis extrusion starts at 0 mm and ends at 3 mm, for a height of 2 mm. Extruder Build time is 12 minutes 26 seconds. Distance extruded is 7185.2 mm. Distance traveled is 8794.5 mm. Extruder speed is 210.0 Extruder was extruding 81.7 percent of the time. Extruder was toggled 102 times. Operating flow rate is 3.1 mm3/s. Feed rate average is 11.8 mm/s, (706.9 mm/min). Filament Cross section area is 0.2 mm2. Extrusion diameter is 0.5 mm. Extrusion fill density ratio is 0.68 Material Mass extruded is 1.5 grams. Volume extruded is 1.4 cc. Meta Text has 1757 lines and a size of 52.0 KB. Version is 2010-06-28 Procedures carve preface inset fill speed temperature raft chamber jitter clip cool Slice Layer thickness is 0.4 mm. Perimeter width is 0.72 mm. The exported file is saved as test_export.gcode It took 11 seconds to export the file.
$ ../../gcodestats.py test_export.gcode Parsing file: test_export.gcode === Commands found: === G1 - 1275 G21 - 2 G28 - 3 G90 - 2 G92 - 3 M101 - 51 M103 - 53 M104 - 11 M105 - 1 M106 - 1 M107 - 1 M108 - 1 M109 - 1 M113 - 4 M115 - 1 M116 - 1 M117 - 1 T0; - 1
Re: Reprap Host beta July 16, 2010 02:31PM |
Re: Reprap Host beta July 16, 2010 02:40PM |
Re: Reprap Host beta July 16, 2010 02:41PM |
Re: Reprap Host beta July 16, 2010 02:52PM |
Re: Reprap Host beta July 16, 2010 03:01PM |
Re: Reprap Host beta July 16, 2010 03:08PM |
Re: Reprap Host beta July 16, 2010 03:10PM |
Re: Reprap Host beta July 16, 2010 03:38PM |
Re: Reprap Host beta July 16, 2010 04:01PM |
Re: Reprap Host beta July 16, 2010 04:10PM |
Re: Reprap Host beta July 16, 2010 04:54PM |
Re: Reprap Host beta July 16, 2010 05:07PM |
Re: Reprap Host beta July 16, 2010 05:08PM |
Re: Reprap Host beta July 25, 2010 04:09PM |
