Installation RepRap auf Debian Linux ? July 15, 2010 10:11PM |
build:
[echo] Reprap: /root/projects/reprap/Reprap/build.xml
[javac] /root/projects/reprap/Reprap/src/org/reprap/gui/botConsole/GenericExtruderTabPanel.java:416: package org.jdesktop.layout does not exist
[javac] .add(jPanel3, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
[javac] ^
[javac] /root/projects/reprap/Reprap/src/org/reprap/gui/botConsole/GenericExtruderTabPanel.java:411: package org.jdesktop.layout does not exist
[javac] .addPreferredGap(org.jdesktop.layout.LayoutStyle.RELATED)
[javac] ^
[javac] 100 errors
BUILD FAILED
/root/projects/reprap/Reprap/build.xml:21: Compile failed; see the compiler error output for details.
Re: Installation RepRap auf Debian Linux ? July 16, 2010 03:22AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Installation RepRap auf Debian Linux ? July 16, 2010 06:13AM |
more /root/projects/reprap/Reprap/build.xml
< ?xml version="1.0" encoding="UTF-8"?>
< !DOCTYPE project [<!ENTITY buildfile SYSTEM "./build-user.xml">]>
< !-- WARNING: Eclipse autogenerated file.
Any modifications will be overwritten.
Please edit build-user.xml instead.
< project basedir="." default="build" name="Reprap">
&buildfile;
< path id="project.classpath">
< pathelement location="bin"/>
< /path>
< target name="init">
< mkdir dir="bin"/>
< /target>
< target name="clean">
< delete dir="bin"/>
< delete dir="jar"/>
< /target>
< target depends="init" name="build">
< echo message="${ant.project.name}: ${ant.file}"/>
< javac source="1.5" target="1.5" destdir="bin">
< src path="src"/>
< classpath refid="project.classpath"/>
< classpath>
< path refid="project.classpath"/>
< path location="lib/swing-layout-1.0.3.jar"/>
< /classpath>
< /javac>
< /target>
< /project>
[java] Exception in thread "AWT-EventQueue-0" java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
[java] at java.util.ArrayList.RangeCheck(ArrayList.java:546)
[java] at java.util.ArrayList.get(ArrayList.java:321)
[java] at org.reprap.geometry.polygons.AllSTLsToBuild.get(Unknown Source)
[java] at org.reprap.gui.RepRapBuild.nextPicked(Unknown Source)
[java] at org.reprap.Main.onNextPicked(Unknown Source)
[java] at org.reprap.Main.access$400(Unknown Source)
[java] at org.reprap.Main$5.actionPerformed(Unknown Source)
[java] at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1849)
[java] at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2169)
[java] at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
[java] at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
[java] at javax.swing.AbstractButton.doClick(AbstractButton.java:302)
[java] at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1050)
[java] at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1091)
[java] at java.awt.Component.processMouseEvent(Component.java:5517)
[java] at javax.swing.JComponent.processMouseEvent(JComponent.java:3129)
[java] at java.awt.Component.processEvent(Component.java:5282)
[java] at java.awt.Container.processEvent(Container.java:1966)
[java] at java.awt.Component.dispatchEventImpl(Component.java:3984)
[java] at java.awt.Container.dispatchEventImpl(Container.java:2024)
[java] at java.awt.Component.dispatchEvent(Component.java:3819)
[java] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4212)
[java] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3892)
[java] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3822)
[java] at java.awt.Container.dispatchEventImpl(Container.java:2010)
[java] at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
[java] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
[java] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
[java] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
[java] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
[java] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Re: Installation RepRap auf Debian Linux ? July 16, 2010 07:17AM |
Re: Installation RepRap auf Debian Linux ? July 16, 2010 07:49AM |
Buildfile: build.xml
init:
build:
[javac] Compiling 8 source files to /root/projects/reprap/Reprap/bin
properties:
backgroundstl:
jar:
run:
[java] Stable Library
[java] =========================================
[java] Native lib Version = RXTX-2.1-7
[java] Java lib Version = RXTX-2.1-7
[java] Error opening port: /dev/ttyUSB0
[java] Java 3D WARNING : reported GLX version = 1.2
[java] GLX version 1.3 or higher is required
[java] The reported version number may be incorrect. There is a known
[java] ATI driver bug in glXQueryVersion that incorrectly reports the GLX
[java] version as 1.2 when it really is 1.3, so Java 3D will attempt to
[java] run anyway.
[java] Exception in thread "RepRap" java.lang.NoClassDefFoundError: org/jdesktop/layout/GroupLayout$Group
[java] at org.reprap.Main$12.run(Unknown Source)
[java] at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
[java] at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
Re: Installation RepRap auf Debian Linux ? July 16, 2010 07:56AM |
[java] run anyway.
Es ist möglich das 1.3 installiert ist deswegen versucht die software trotzdem zu laufen aber solte GLX version 1.3 oder hoher nicht Installiert sein denn es kann einfach nicht gehen!|
Re: Installation RepRap auf Debian Linux ? July 16, 2010 08:19AM |
Re: Installation RepRap auf Debian Linux ? July 16, 2010 08:33AM |
C:\Program Files\RepRap>rem reprap-host -- runs Reprap Java host code with an ap propriate classpath C:\Program Files\RepRap>rem Amount of RAM to allow Java VM to use C:\Program Files\RepRap>set REPRAP_RAM_SIZE=1024M C:\Program Files\RepRap>rem reprap.jar file and stl file C:\Program Files\RepRap>set REPRAP_DIR=C:\Program Files\Reprap C:\Program Files\RepRap>rem Java3D and j3d.org libraries C:\Program Files\RepRap>rem set JAVA_LIBRARY_DIR=C:\Program Files\Reprap C:\Program Files\RepRap>rem cd so we can find the reprap-wv.stl file. Can we av oid this?? C:\Program Files\RepRap>IF NOT EXIST reprap-wv.stl cd "C:\Program Files\Reprap" C:\Program Files\RepRap>java -cp ".\reprap.jar;.\RXTXcomm.jar;.\j3dcore.jar;.\j3 d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3.jar;.\vecmath.jar;." -X mx1024M org/reprap/Main DEBUG: The distribution preferences file contains: Extruder3_MaxSpeed(0..255) Extruder3_MinimumZClearance(mm) Extruder3_ExtrusionDelayForLayer(ms) Extruder3_ExtrusionBroadWidth(mm) Extruder3_Beta(K) Extruder3_AngleSpeedFactor(0..1) Extruder3_ExtrusionHeight(mm) Extruder3_NozzleWipeStrokeY(mm) Extruder3_ShortSpeed(0..1) Extruder3_MaterialType(name) Extruder3_ExtrusionSize(mm) Extruder3_FastEFeedrate(mm/minute) Extruder3_OddHatchDirection(degrees) Extruder3_ExtrusionDelayForPolygon(ms) Extruder3_ExtrusionPWM(0..1) Extruder3_Capacitor(F) Extruder3_NozzleWipeStrokeX (mm) Extruder2_FastEFeedrate(mm/minute) Extruder3_t0(0..255) Extruder3_ColourG(0..1) Extruder3_NozzleWaitTime(s) Extruder1_FastEFeedrate(mm/minute) Extruder3_NozzleClearTime(s) Extruder3_NozzleWipeFreq Extruder0_Purge(ms) Extruder0_FastEFeedrate(mm/minute) Extruder3_Purge(ms) Extruder3_ExtrusionSpeed(mm/minute) Extruder3_Address Extruder3_ExtrusionInfillWidth(mm) Extruder3_SeparationOutlineSpeed(0..1) Extruder3_InfillSpeed(0..1) Extruder3_CoolingPeriod(s) Extruder3_NozzleWipeEnabled Extruder3_ArcCompensationFactor(0..) Extruder3_SupportMaterialType(name) Extruder3_SeparationFraction(0..1) Extruder3_AngleSpeedLength(mm) Extruder3_OffsetZ(mm) Extruder3_ValveDelayForLayer(ms) Extruder3_MaxAcceleration(mm/minute/minute) FinishY(mm) Extruder3_NozzleWipeDatumY(mm) Extruder3_hm(C/pwr) Extruder3_ShortLength(mm) Extruder3_InFillMaterialType(name) Extruder0_ExtrusionPWM(0..1) Extruder3_ExtrusionOverRun(mm) Extruder3_OffsetY(mm) Extruder3_SlowXYFeedrate(mm/minute) Extruder3_LowerFineLayers(0...) FinishX (mm) Extruder3_NozzleWipeDatumX (mm) Extruder3_RandomStart Extruder3_ArcShortSides(0..) Extruder3_ExtrudeRatio(0..) BedTemperature(C) Extruder3_OffsetX (mm) Extruder3_IncrementedStart Extruder3_FastXYFeedrate(mm/minute) Extruder3_hb(C) Extruder2_Purge(ms) Extruder3_ColourB(0..1) Extruder3_ValveOverRun(mm) Extruder3_PauseBetweenSegments Extruder3_ValveDelayForPolygon(ms) Extruder3_InfillOverlap(mm) Extruder3_ValvePulseTime(ms) Extruder3_ExtrusionFoundationWidth(mm) Extruder1_ExtrusionPWM(0..1) DumpY( mm) Extruder3_Reverse(ms) Extruder3_SeparationSpeed(mm/minute) DumpX (mm) Extruder3_UpperFineLayers(0...) Extruder3_EvenHatchDirection(degrees) Extruder3_ExtrusionLastFoundationWidth(mm) Extruder3_OutlineSpeed(0..1) Extruder3_Rz(ohms) Extruder1_Purge(ms) Extruder2_ExtrusionPWM(0..1) Extruder3_ColourR(0..1) Extruder3_NumberOfShells(0..N) PathOptimise Extruder3_ExtrusionTemp(C) Shield which are not in your preferences file. [0.015s/-1279283244438ms] DEBUG: GCode opening port COM8 [0.250s/235ms] Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 Error opening port: COM8 RepRap preference: MainWindowWidth not found in either preference file. RepRap preference: MainWindowLeft not found in either preference file. DEBUG: bufferQueue: attempt to queue: T8; select new extruder to a non-running o utput buffer. [3.890s/3640ms] DEBUG: bufferQueue: attempt to queue: M113; set extruder to use pot for PWM to a non-running output buffer. [3.890s/0ms] DEBUG: queueRespond: attempt to queue: M105; get temperature to a non-running ou tput buffer. [3.890s/0ms] DEBUG: queueRespond: attempt to queue: M105; get temperature to a non-running ou tput buffer. [5.406s/1516ms] DEBUG: queueRespond: attempt to queue: M105; get temperature to a non-running ou tput buffer. [6.906s/1500ms]
Re: Installation RepRap auf Debian Linux ? July 16, 2010 03:22PM |
Jetzt keine rm * Witze
Re: Installation RepRap auf Debian Linux ? July 18, 2010 08:34PM |
