Alternative RepRap Elektronik im Eigenbau August 20, 2010 09:08PM |
Re: Alternative RepRap Elektronik im Eigenbau August 22, 2010 03:06AM |
Re: Alternative RepRap Elektronik im Eigenbau August 22, 2010 05:22AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Alternative RepRap Elektronik im Eigenbau August 22, 2010 06:41AM |
Re: Alternative RepRap Elektronik im Eigenbau August 22, 2010 07:27AM |
Re: Alternative RepRap Elektronik im Eigenbau August 22, 2010 07:42AM |
Re: Alternative RepRap Elektronik im Eigenbau August 23, 2010 03:03AM |
Re: Alternative RepRap Elektronik im Eigenbau August 26, 2010 03:16PM |
Re: Alternative RepRap Elektronik im Eigenbau August 26, 2010 03:20PM |
Re: Alternative RepRap Elektronik im Eigenbau August 26, 2010 03:55PM |
Re: Alternative RepRap Elektronik im Eigenbau August 26, 2010 03:57PM |
Re: Alternative RepRap Elektronik im Eigenbau August 26, 2010 04:52PM |
wie einer seine Pololus kühlt
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: Alternative RepRap Elektronik im Eigenbau September 03, 2010 04:03PM |
Kommunikation PC <=> Motherboard mit eigener Elektronik:
comms: G-code: N370 M105 *3 dequeued and sent [1621,063s/7ms]
ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Resend:0 [1621,063s/0ms]
comms: Response: Resend:0 [1621,063s/0ms]
comms: G-code: N370 M105 *3 dequeued and sent [1621,071s/8ms]
comms: Response: ok [1621,071s/0ms]
ERROR: GCodeReaderAndWriter.getETemp() - no value stored! [1621,071s/0ms]
comms: G-code: N371 M105 *2 dequeued and sent [1621,079s/8ms]
ERROR: GCodeWriter.waitForResponse() - dud response from RepRaperial Error: Linenumber (370) is not last + 1 (0), line received: N370 M105 *3 [1621,099s/20ms]
comms: Response: Serial Error: Linenumber (370) is not last + 1 (0), line received: N370 M105 *3 [1621,099s/0ms]
comms: G-code: N371 M105 *2 dequeued and sent [1621,107s/8ms]
ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Resend:0 [1621,107s/0ms]
comms: Response: Resend:0 [1621,107s/0ms]
Re: Alternative RepRap Elektronik im Eigenbau September 03, 2010 04:37PM |
Wiederholung des Tests mit passender Firmware
comms: G-code: N0 T0 *26 dequeued and sent [0,001s/-1283545758553ms]
comms: Response: ok [0,003s/2ms]
comms: G-code: N1 M113 *1 dequeued and sent [0,011s/8ms]
comms: Response: ok [0,015s/4ms]
comms: G-code: N2 M105 *5 dequeued and sent [0,023s/8ms]
comms: Response: ok T:255 B:401 [0,031s/8ms]
comms: G-code: N3 M105 *4 dequeued and sent [1,539s/1508ms]
comms: Response: ok T:255 B:409 [1,553s/14ms]
comms: G-code: N4 M105 *3 dequeued and sent [3,075s/1522ms]
comms: Response: ok T:255 B:409 [3,079s/4ms]
comms: G-code: N5 M105 *2 dequeued and sent [3,107s/28ms]
comms: Response: ok T:255 B:409 [3,111s/4ms]
comms: G-code: N6 M105 *1 dequeued and sent [4,619s/1508ms]
comms: Response: ok T:255 B:409 [4,627s/8ms]
comms: G-code: N7 M105 *0 dequeued and sent [6,135s/1508ms]
comms: Response: ok T:255 B:409 [6,143s/8ms]
comms: G-code: N8 M105 *15 dequeued and sent [7,651s/1508ms]
comms: Response: ok T:255 B:401 [7,659s/8ms]
comms: G-code: N9 M105 *14 dequeued and sent [7,667s/8ms]
comms: Response: ok T:255 B:401 [7,675s/8ms]
comms: G-code: N10 M105 *54 dequeued and sent [9,183s/1508ms]
comms: Response: ok T:255 B:401 [9,196s/13ms]
Re: Alternative RepRap Elektronik im Eigenbau September 03, 2010 04:56PM |
Re: Alternative RepRap Elektronik im Eigenbau September 03, 2010 05:04PM |
Offenbar war mein Verdacht korrekt.
Re: Alternative RepRap Elektronik im Eigenbau September 03, 2010 05:08PM |
Re: Alternative RepRap Elektronik im Eigenbau September 03, 2010 05:52PM |
Re: Alternative RepRap Elektronik im Eigenbau September 03, 2010 06:09PM |
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 03:57PM |
Die erste wird bei Motherboard-Version 1 verwendet, die zweite bei Version 3. Aber man kann nicht einfach auswählen, sondern diese Versionsvariablen haben Auswirkungen auf viele andere Dinge.Quote
Firmware-Varianten:
static extruder ex0(
EXTRUDER_0_MOTOR_DIR_PIN,
EXTRUDER_0_MOTOR_SPEED_PIN,
EXTRUDER_0_HEATER_PIN,
EXTRUDER_0_FAN_PIN,
EXTRUDER_0_TEMPERATURE_PIN,
EXTRUDER_0_VALVE_DIR_PIN,
EXTRUDER_0_VALVE_ENABLE_PIN,
EXTRUDER_0_STEP_ENABLE_PIN,
E0_STEPS_PER_MM);
EXTRUDER_0_STEP_PIN,
EXTRUDER_0_DIR_PIN,
EXTRUDER_0_ENABLE_PIN,
E0_STEPS_PER_MM);
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 05:11PM |
Ein Problem ist, dass es zwei Extrudervarianten gibt:
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 05:17PM |
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 05:30PM |
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 05:49PM |
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 06:44PM |
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 07:12PM |
Re: Alternative RepRap Elektronik im Eigenbau September 04, 2010 08:45PM |
Re: Alternative RepRap Elektronik im Eigenbau September 05, 2010 02:00AM |
Re: Alternative RepRap Elektronik im Eigenbau September 05, 2010 02:47AM |
