| Aller Anfang war schwer - Wolfstrap | Reprap-fab.org | ![]() |
Re: OpenScad December 22, 2010 06:14AM |
Re: OpenScad December 22, 2010 06:20AM |
Re: OpenScad December 22, 2010 06:30AM |
Re: OpenScad December 22, 2010 06:36AM |
Re: OpenScad December 22, 2010 07:40AM |
WadeL_double_helix();
module WadeL_double_helix(){
//Large WADE's Gear - Double Helix
//rotate([0,0,-2])translate([0,0,0])color([ 100/255, 255/255, 200/255])import_stl("39t17p.stl");
circles=8;
teeth=39;
pitch=268;
twist=200;
height=12;
pressure_angle=30;
difference(){
union(){
gear (number_of_teeth=teeth,
circular_pitch=pitch,
pressure_angle=pressure_angle,
clearance = 0.2,
gear_thickness = height/2*0.5,
rim_thickness = height/2,
rim_width = 5,
hub_thickness = height/2*1.5,
hub_diameter = 25,
bore_diameter = 8,
circles=circles,
twist = twist/teeth);
mirror([0,0,1])
clearance = 0.2,
gear_thickness = height/2,
rim_width = 5,
hub_thickness = height/2,
hub_diameter=25,
bore_diameter=8,
circles=circles,
twist=twist/teeth);
translate([0,0,6])rotate([180,0,0])m8_hole_vert_with_hex(100);
Re: OpenScad December 22, 2010 08:29AM |
und die Bohrungen für die kleine Schraube sind verschwunden..| Aller Anfang war schwer - Wolfstrap | Reprap-fab.org | ![]() |
Re: OpenScad December 22, 2010 09:05AM |
Re: OpenScad December 22, 2010 09:43AM |
Re: OpenScad December 22, 2010 09:57AM |
translate([0,-5,13])cube([5.5,2.3,9],center = true); translate([0,0,11])rotate([0,90,-90])cylinder(r=1.7,h=20);
Re: OpenScad December 22, 2010 10:10AM |
Re: OpenScad December 23, 2010 10:53AM |
Re: OpenScad December 23, 2010 12:37PM |
Re: OpenScad December 23, 2010 01:06PM |
