Stromversorgung Mainboard? December 31, 2010 12:18PM |
Re: Stromversorgung Mainboard? December 31, 2010 12:23PM |
Re: Stromversorgung Mainboard? December 31, 2010 12:42PM |
| Aller Anfang war schwer - Wolfstrap | Reprap-fab.org | ![]() |
Re: Stromversorgung Mainboard? December 31, 2010 12:47PM |
Re: Stromversorgung Mainboard? December 31, 2010 01:15PM |
Re: Stromversorgung Mainboard? December 31, 2010 01:22PM |
also das Board ist ein V1.2 (TechzoneRemix) das bekommt seinen Strom wohl auch über USB.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Stromversorgung Mainboard? December 31, 2010 01:57PM |
Re: Stromversorgung Mainboard? December 31, 2010 02:03PM |
Re: Stromversorgung Mainboard? December 31, 2010 03:01PM |
Re: Stromversorgung Mainboard? December 31, 2010 03:24PM |
Re: Stromversorgung Mainboard? December 31, 2010 03:37PM |
Re: Stromversorgung Mainboard? December 31, 2010 08:41PM |
Re: Stromversorgung Mainboard? January 01, 2011 03:24PM |
Re: Stromversorgung Mainboard? January 01, 2011 03:53PM |
Re: Stromversorgung Mainboard? January 01, 2011 07:00PM |
Re: Stromversorgung Mainboard? January 02, 2011 07:58AM |
Re: Stromversorgung Mainboard? January 03, 2011 05:47AM |
Re: Stromversorgung Mainboard? January 03, 2011 07:49AM |
Re: Stromversorgung Mainboard? January 03, 2011 12:59PM |
#define Z_STEPS_PER_MM 80 #define Z_STEPS_PER_INCH (Z_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Z_DIR 0 ... //our maximum feedrates in mm/minute #define FAST_XY_FEEDRATE 1500.0 #define FAST_Z_FEEDRATE 1500.0 // Data for acceleration calculations // Comment out the next line to turn accelerations off #define ACCELERATION_ON #define SLOW_XY_FEEDRATE 30.0 // Speed from which to start accelerating #define SLOW_Z_FEEDRATE 30.0
Re: Stromversorgung Mainboard? January 03, 2011 01:10PM |
Re: Stromversorgung Mainboard? January 03, 2011 01:31PM |
#ifndef CONFIGURATION_H #define CONFIGURATION_H /* * This is the configuration file for the RepRap Motherboard microcontroller. * Set values in it to match your RepRap machine. * * Lines in here with a * * // *RO * * Comment at the end (read-only) should probably only be changed if you really * know what you are doing... */ // Here are the Motherboard codes; set MOTHERBOARD to the right one // A standard Mendel is MOTHERBOARD 2 // (Arduino: 0 - no longer in use) // Sanguino or RepRap Motherboard with direct drive extruders: 1 // RepRap Motherboard with RS485 extruders: 2 // Arduino Mega: 3 #define MOTHERBOARD 2 // The width of Henry VIII's thumb (or something). #define INCHES_TO_MM 25.4 // *RO // The number of real extruders in this machine #define EXTRUDER_COUNT 1 //********************************************************************************************** // These settings are mainly for a standard Mendel //********************************************************************************************* #if MOTHERBOARD == 2 // Comment out the next line if you are running a Darwin with a MOTHERBOARD > 1 #define MENDEL 1 // Set to 1 if enable pins are inverting // For RepRap stepper boards version 1.x the enable pins are *not* inverting. // For RepRap stepper boards version 2.x and above the enable pins are inverting. #define INVERT_ENABLE_PINS 1 // Set to one if the axis opto-sensor outputs inverting (ie: 1 means open, 0 means closed) // RepRap opto endstops with H21LOI sensors are not inverting; ones with H21LOB // are inverting. #define X_ENDSTOP_INVERTING false #define Y_ENDSTOP_INVERTING false #define Z_ENDSTOP_INVERTING false #define MY_NAME 'H' // Byte representing the name of this device #define E0_NAME '0' // Byte representing the name of extruder 0 #define E1_NAME '1' // Byte representing the name of extruder 1 #define RS485_MASTER 1 // *RO // Axis scaling in stepper-motor steps per mm of movement #define X_STEPS_PER_MM 80 #define X_STEPS_PER_INCH (X_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_X_DIR 0 #define Y_STEPS_PER_MM 80 #define Y_STEPS_PER_INCH (Y_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Y_DIR 0 #define Z_STEPS_PER_MM 80 #define Z_STEPS_PER_INCH (Z_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Z_DIR 0 // Stepper-driven extruder // E_STEPS_PER_MM is the number of steps needed to // extrude 1mm out of the nozzle. E0 for extruder 0; // E1 for extruder 1, and so on. //#define E_STEPS_PER_MM 0.9 // NEMA 17 extruder 5mm diameter drive - empirically adjusted //#define E0_STEPS_PER_MM 2 // NEMA 17 59/11 geared extruder 8mm diameter drive //#define E1_STEPS_PER_MM 2.2 // NEMA 17 59/11 geared extruder 8mm diameter drive #define E0_STEPS_PER_MM 5 // Gefräster Extruder #endif //********************************************************************************************** // These settings are mainly for a Mendel with an Arduino Mega controller and Pololu stepper drivers // See [reprap.org] //********************************************************************************************* //********************************************************************************************** // All other Settings not specific to the motherboard type: //********************************************************************************************* // The speed at which to talk with the host computer; default is 19200 #define HOST_BAUD 19200 // *RO // Set 1s where you have endstops; 0s where you don't // Both Darwin and Mendel have MIN endstops, but not MAX ones. #define ENDSTOPS_MIN_ENABLED 1 #define ENDSTOPS_MAX_ENABLED 0 // The number of mm below which distances are insignificant (one tenth the // resolution of the machine is the default value). #define SMALL_DISTANCE 0.01 // *RO // Useful to have its square #define SMALL_DISTANCE2 (SMALL_DISTANCE*SMALL_DISTANCE) // *RO //our maximum feedrates in mm/minute #define FAST_XY_FEEDRATE 3000.0 #define FAST_Z_FEEDRATE 3000.0 // Data for acceleration calculations // Comment out the next line to turn accelerations off #define ACCELERATION_ON #define SLOW_XY_FEEDRATE 1000.0 // Speed from which to start accelerating #define SLOW_Z_FEEDRATE 1000.0 #if INVERT_ENABLE_PINS == 1 // *RO #define ENABLE_ON LOW // *RO #else // *RO #define ENABLE_ON HIGH // *RO #endif // *RO // Set these to 1 to disable an axis when it's not being used, // and for the extruder. Usually only Z is disabled when not in // use. You will probably find that disabling the others (i.e. // powering down the steppers that drive them) when the ends of // movements are reached causes poor-quality builds. (Inertia // causes overshoot if the motors are not left powered up.) #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 0 #define DISABLE_E 0 // The number of 5-second intervals to wait at the target temperature for things to stabilise. // Too short, and the extruder will jam as only part of it will be hot enough. // Too long and the melt will extend too far up the insulating tube. // Default value: 10 #define WAIT_AT_TEMPERATURE 10 // PID gains. These are about right for a brass extruder about 8 mm // in diameter and 30 mm long heated by a 6 ohm coil with a 12v supply. #define TEMP_PID_PGAIN 2 #define TEMP_PID_IGAIN 0.07 #define TEMP_PID_DGAIN 1 //our command string length #define COMMAND_SIZE 128 // *RO // Our response string length #define RESPONSE_SIZE 256 // *RO // The size of the movement buffer #define BUFFER_SIZE 4 // *RO // Number of microseconds between timer interrupts when no movement // is happening #define DEFAULT_TICK (long)1000 // *RO // What delay() value to use when waiting for things to free up in milliseconds #define WAITING_DELAY 1 // *RO //****************************************************************************** // You probably only want to edit things below this line if you really really // know what you are doing... void delayMicrosecondsInterruptible(unsigned int us); // Inline interrupt control functions inline void enableTimerInterrupt() { TIMSK1 |= (1<Edited 1 time(s). Last edit at 01/03/2011 01:56PM by goaran.
my projects: [www.robotik.dyyyh.de] ...
Re: Stromversorgung Mainboard? January 03, 2011 02:42PM |
Re: Stromversorgung Mainboard? January 03, 2011 03:05PM |
void zero) { where_i_am.f = SLOW_XY_FEEDRATE; specialMove
where_i_am.x - 5, FAST_XY_FEEDRATE); specialMove
where_i_am.x - 250, FAST_XY_FEEDRATE); where_i_am.x = 0; where_i_am.f = SLOW_XY_FEEDRATE; specialMove
where_i_am.x + 1, SLOW_XY_FEEDRATE); specialMove
where_i_am.x - 10, SLOW_XY_FEEDRATE); where_i_am.x = 0; } void zeroY() { specialMoveY(where_i_am.y - 5, FAST_XY_FEEDRATE); specialMoveY(where_i_am.y - 250, FAST_XY_FEEDRATE); where_i_am.y = 0; where_i_am.f = SLOW_XY_FEEDRATE; specialMoveY(where_i_am.y + 1, SLOW_XY_FEEDRATE); specialMoveY(where_i_am.y - 10, SLOW_XY_FEEDRATE); where_i_am.y = 0; } void zeroZ() { where_i_am.f = SLOW_Z_FEEDRATE; specialMoveZ(where_i_am.z - 0.5, FAST_Z_FEEDRATE); specialMoveZ(where_i_am.z - 250, FAST_Z_FEEDRATE); where_i_am.z = 0; where_i_am.f = SLOW_Z_FEEDRATE; specialMoveZ(where_i_am.z + 1, SLOW_Z_FEEDRATE); specialMoveZ(where_i_am.z - 2, SLOW_Z_FEEDRATE); where_i_am.z = 0; } da sind bei Z die Werte anders, aber wenn ich sie wie bei XY setzte ändert sich auch nichts.
Re: Stromversorgung Mainboard? January 03, 2011 03:26PM |
-- different pulleys on X and Y axii -- axis id="x" length="100" maxfeedrate="5000" scale="11.767463" axis id="y" length="100" maxfeedrate="5000" scale="11.767463" axis id="z" length="100" maxfeedrate="150" scale="320"
Re: Stromversorgung Mainboard? January 03, 2011 03:38PM |
Re: Stromversorgung Mainboard? January 03, 2011 03:44PM |
Re: Stromversorgung Mainboard? January 03, 2011 03:56PM |
Re: Stromversorgung Mainboard? January 03, 2011 04:08PM |
Re: Stromversorgung Mainboard? January 03, 2011 04:10PM |
Re: Stromversorgung Mainboard? January 03, 2011 04:19PM |
