Juhu... Teilerfolg.
sanguino.name=Sanguino
sanguino.upload.protocol=stk500
sanguino.upload.maximum_size=63488
sanguino.upload.speed=38400
sanguino.bootloader.low_fuses=0xFF
sanguino.bootloader.high_fuses=0xDC
sanguino.bootloader.extended_fuses=0xFD
sanguino.bootloader.path=atmega644p
sanguino.bootloader.file=ATmegaBOOT_644.hex
sanguino.bootloader.unlock_bits=0x3F
sanguino.bootloader.lock_bits=0x0F
sanguino.build.mcu=atmega644
sanguino.build.f_cpu=16000000L
sanguino.build.core=sanguino
sanguino.verbose=false
in die Boards.txt eingefügt (hardware\arduino) nun kommt:
FiveD_GCode_Interpreter.cpp:3:28: error: HardwareSerial.h: No such file or directory
FiveD_GCode_Interpreter.cpp:5:22: error: WProgram.h: No such file or directory
In file included from FiveD_GCode_Interpreter.cpp:11:
/pins.h:128:2: error: #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
In file included from FiveD_GCode_Interpreter.cpp:6:
/vectors.h: In function 'FloatPoint fabsv(const FloatPoint&)':
vectors.h:73: error: 'fabs' was not declared in this scope
/vectors.h: In function 'LongPoint absv(const LongPoint&)':
vectors.h:118: error: 'abs' was not declared in this scope
In file included from FiveD_GCode_Interpreter.cpp:7:
/features.h: At global scope:
features.h:222: error: 'byte' does not name a type
In file included from FiveD_GCode_Interpreter.cpp:9:
hostcom.h:84: error: 'byte' does not name a type
/hostcom.h: In member function 'void hostcom::putInit()':
hostcom.h:111: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(const char*)':
hostcom.h:112: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(const float&)':
hostcom.h:113: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(const long int&)':
hostcom.h:114: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(int)':
hostcom.h:115: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put(double)':
hostcom.h:116: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::put()':
hostcom.h:117: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::putEnd()':
hostcom.h:118: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::putWs()':
hostcom.h:119: error: 'Serial' was not declared in this scope
/hostcom.h: At global scope:
hostcom.h:120: error: 'byte' does not name a type
/hostcom.h: In member function 'char hostcom::get()':
hostcom.h:121: error: 'Serial' was not declared in this scope
/hostcom.h: In member function 'void hostcom::sendMessage(bool)':
hostcom.h:306: error: 'ACCELERATION' was not declared in this scope
In file included from FiveD_GCode_Interpreter.cpp:10:
/intercom.h: At global scope:
intercom.h:109: error: 'byte' does not name a type
intercom.h:111: error: 'byte' does not name a type
In file included from FiveD_GCode_Interpreter.cpp:12:
/Temperature.h: In function 'void setupThermistors()':
Temperature.h:327: error: 'temptable' was not declared in this scope
Temperature.h:330: error: 'bedtemptable' was not declared in this scope
In file included from FiveD_GCode_Interpreter.cpp:15:
/extruder.h: At global scope:
extruder.h:12: error: variable or field 'newExtruder' declared void
extruder.h:12: error: 'byte' was not declared in this scope
extruder.h:171: error: 'byte' has not been declared
/extruder.h: In constructor 'extruder::extruder(char, float)':
extruder.h:209: error: 'OUTPUT' was not declared in this scope
extruder.h:209: error: 'pinMode' was not declared in this scope
extruder.h:211: error: 'digitalWrite' was not declared in this scope
/extruder.h: In member function 'void extruder::buildNumberCommand(char, int)':
extruder.h:234: error: 'itoa' was not declared in this scope
/extruder.h: In member function 'void extruder::valveSet(bool, int)':
extruder.h:248: error: 'delay' was not declared in this scope
extruder.h:251: error: variable or field 'setCooler' declared void
extruder.h:251: error: 'byte' was not declared in this scope
/extruder.h: In member function 'int extruder::getTemperature()':
extruder.h:273: error: 'atoi' was not declared in this scope
/extruder.h: In member function 'int extruder::getBedTemperature()':
extruder.h:287: error: 'atoi' was not declared in this scope
/extruder.h: In member function 'void extruder::setDirection(bool)':
extruder.h:303: error: 'digitalWrite' was not declared in this scope
extruder.h:305: error: 'digitalWrite' was not declared in this scope
/extruder.h: In member function 'void extruder::sStep()':
extruder.h:315: error: 'digitalWrite' was not declared in this scope
extruder.h:317: error: 'digitalWrite' was not declared in this scope
/extruder.h: In member function 'int extruder::potVoltage()':
extruder.h:346: error: 'atoi' was not declared in this scope
extruder.h:514: error: 'byte' does not name a type
In file included from FiveD_GCode_Interpreter.cpp:16:
/cartesian_dda.h: In member function 'void cartesian_dda::do_x_step()':
cartesian_dda.h:151: error: 'HIGH' was not declared in this scope
cartesian_dda.h:151: error: 'digitalWrite' was not declared in this scope
cartesian_dda.h:152: error: 'LOW' was not declared in this scope
/cartesian_dda.h: In member function 'void cartesian_dda::do_y_step()':
cartesian_dda.h:157: error: 'HIGH' was not declared in this scope
cartesian_dda.h:157: error: 'digitalWrite' was not declared in this scope
cartesian_dda.h:158: error: 'LOW' was not declared in this scope
/cartesian_dda.h: In member function 'void cartesian_dda::do_z_step()':
cartesian_dda.h:163: error: 'HIGH' was not declared in this scope
cartesian_dda.h:163: error: 'digitalWrite' was not declared in this scope
cartesian_dda.h:164: error: 'LOW' was not declared in this scope
/cartesian_dda.h: In member function 'void cartesian_dda::do_e_step()':
cartesian_dda.h:169: error: 'extruder_in_use' was not declared in this scope
/cartesian_dda.h: In member function 'bool cartesian_dda::xCanStep(long int, long int, bool)':
cartesian_dda.h:195: error: 'endstop_hits' was not declared in this scope
cartesian_dda.h:211: error: 'digitalRead' was not declared in this scope
/cartesian_dda.h: In member function 'bool cartesian_dda::yCanStep(long int, long int, bool)':
cartesian_dda.h:263: error: 'endstop_hits' was not declared in this scope
cartesian_dda.h:279: error: 'digitalRead' was not declared in this scope
/cartesian_dda.h: In member function 'bool cartesian_dda::zCanStep(long int, long int, bool)':
cartesian_dda.h:330: error: 'endstop_hits' was not declared in this scope
cartesian_dda.h:346: error: 'digitalRead' was not declared in this scope
FiveD_GCode_Interpreter.cpp: At global scope:
FiveD_GCode_Interpreter:2: error: variable or field 'setTimerResolution' declared void
FiveD_GCode_Interpreter:2: error: 'byte' was not declared in this scope
FiveD_GCode_Interpreter:6: error: variable or field 'newExtruder' declared void
FiveD_GCode_Interpreter:6: error: 'byte' was not declared in this scope
FiveD_GCode_Interpreter:22: error: variable or field 'setTimerResolution' declared void
FiveD_GCode_Interpreter:22: error: 'byte' was not declared in this scope
FiveD_GCode_Interpreter:64: error: 'byte' does not name a type
FiveD_GCode_Interpreter:139: error: 'byte' does not name a type
FiveD_GCode_Interpreter:140: error: 'byte' does not name a type
FiveD_GCode_Interpreter:143: error: 'word' does not name a type
FiveD_GCode_Interpreter:155: error: 'byte' does not name a type
FiveD_GCode_Interpreter:168: error: expected constructor, destructor, or type conversion before '(' token
RepRap Newbie. 2x Gebrauchte Elektronik erstanden, Prusa Teile vom Wolfgang, Elektronik wehrt sich :-(
