Gen7 Firmware August 14, 2011 05:56PM |
#define STEPPER_ENABLE_PIN DIO24
/***************************************************************************\ * * * Define your temperature sensors here * * * * for GEN3 set temp_type to TT_INTERCOM and temp_pin to 0 * * * * Types are same as TEMP_ list above- TT_MAX6675, TT_THERMISTOR, TT_AD595, * * TT_PT100, TT_INTERCOM. See list in temp.c. * * * \***************************************************************************/ #ifndef DEFINE_TEMP_SENSOR #define DEFINE_TEMP_SENSOR(...) #endif // name type pin additional //DEFINE_TEMP_SENSOR(extruder, TT_THERMISTOR, 0, THERMISTOR_EXTRUDER) //DEFINE_TEMP_SENSOR(bed, TT_THERMISTOR, 1, THERMISTOR_EXTRUDER) // "noheater" is a special name for a sensor which doesn't have a heater. // Use "M105 P#" to read it, where # is a zero-based index into this list. // DEFINE_TEMP_SENSOR(noheater, TT_THERMISTOR, 1, 0) // to get both thermistors working make sure to use an appropriate 'ThermistorTable.h' file! // See 'ThermistorTable.gen7.h' for an example DEFINE_TEMP_SENSOR(extruder, TT_THERMISTOR, PINA1, THERMISTOR_EXTRUDER) DEFINE_TEMP_SENSOR(bed, TT_THERMISTOR, PINA2, THERMISTOR_BED)
Re: Gen7 Firmware August 14, 2011 06:27PM |
lösen konnte ich das problem indem ich
auskommentiert habe. denke mal nicht, dass das normal ist?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen7 Firmware August 15, 2011 12:18PM |
Re: Gen7 Firmware August 15, 2011 01:40PM |
Re: Gen7 Firmware August 15, 2011 02:36PM |
Re: Gen7 Firmware August 15, 2011 03:03PM |
Re: Gen7 Firmware August 15, 2011 04:28PM |
Re: Gen7 Firmware August 15, 2011 05:36PM |
T:0.0 B:0.0 T:0.0 B:0.0 T:0.0 B:0.0 T:0.0 B:0.0 T:0.0 B:0.0 T:0.0 B:232.0 << kurzschluss test T:0.0 B:30.25 T:0.0 B:0.0 T:0.0 B:0.0 T:0.0 B:0.0 T:0.0 B:30.50 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 SENDING:M84 T:0.0 B:30.0 SENDING:M84 T:0.0 B:30.0 >z-achse T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:232.0 << kurzschluss test T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 start Printer is now online T:232.0 B:232.0 << kurzschluss test T:0.0 B:0.0 T:3.0 B:0.0 T:3.0 B:0.0 T:3.0 B:0.0 T:3.0 B:0.0 T:3.0 B:7710.0 > y-achse T:3.0 B:7710.0 T:3.0 B:7710.0 T:0.0 B:7710.0 T:0.0 B:7710.0 T:0.0 B:7710.0 T:0.0 B:30.50 > z-achse T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:30.0 T:0.0 B:22.0 T:0.0 B:22.0 T:0.0 B:22.0 T:0.0 B:22.0 T:0.0 B:22.0 T:0.0 B:22.0 T:0.0 B:22.0 T:0.25 B:22.0 T:0.25 B:22.0 T:0.25 B:30.0 T:0.0 B:2460.0 >x-achse T:0.0 B:2460.0 SENDING:M84 T:0.0 B:2460.0 T:0.0 B:2460.0 T:0.0 B:2460.0
Re: Gen7 Firmware August 16, 2011 03:14AM |
Re: Gen7 Firmware August 16, 2011 04:32AM |
Re: Gen7 Firmware August 16, 2011 05:07AM |
Re: Gen7 Firmware August 16, 2011 05:11AM |
Re: Gen7 Firmware August 16, 2011 05:00PM |
//Thermistor Test für Atmega 644 void setup() { pinMode(15, OUTPUT); digitalWrite(15, LOW); Serial.begin(9600); } void loop() { int sensorValue1 = analogRead(1); Serial.print( "Temp1: "); Serial.print(sensorValue1); int sensorValue2 = analogRead(2); Serial.print(" Temp2: "); Serial.print(sensorValue2); Serial.print("\n"); delay(200); }
Re: Gen7 Firmware August 16, 2011 05:19PM |
Re: Gen7 Firmware August 16, 2011 06:02PM |
Re: Gen7 Firmware August 17, 2011 04:58AM |
Re: Gen7 Firmware August 17, 2011 08:21AM |
