Verbindungsabbruch August 25, 2011 03:06AM |
Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14636, in
lambda event: event.callable(*event.args, **event.kw) )
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 1850, in AppendText
return _controls_.TextCtrl_AppendText(*args, **kwargs)
File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf8' codec can't decode byte 0x9d in position 9: invalid start byte
sat
Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 505, in run
self.__target(*self.__args, **self.__kwargs)
File "/home/otelo/Arbeitsfläche/Prusa/kliment-Printrun-5505285/printcore.py", line 79, in _listen
line=self.printer.readline()
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 456, in read
raise SerialException('device reports readiness to read but returned no data (device disconnected?)')
SerialException: device reports readiness to read but returned no data (device disconnected?)
Re: Verbindungsabbruch August 25, 2011 03:26AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Verbindungsabbruch August 25, 2011 04:06AM |
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: Verbindungsabbruch August 25, 2011 04:13AM |
Re: Verbindungsabbruch August 25, 2011 04:18AM |
Re: Verbindungsabbruch August 25, 2011 04:45AM |
Re: Verbindungsabbruch August 25, 2011 06:25AM |
java.lang.UnsatisfiedLinkError: /home/otelo/reprap-host-linux-20090804/librxtxSerial.so: /home/otelo/reprap-host-linux-20090804/librxtxSerial.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch) thrown while loading gnu.io.RXTXCommDriver
Exception in thread "RepRap" java.lang.UnsatisfiedLinkError: /home/otelo/reprap-host-linux-20090804/librxtxSerial.so: /home/otelo/reprap-host-linux-20090804/librxtxSerial.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1807)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1732)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1028)
at gnu.io.CommPortIdentifier.(CommPortIdentifier.java:83)
at org.reprap.comms.GCodeReaderAndWriter.openSerialConnection(Unknown Source)
at org.reprap.comms.GCodeReaderAndWriter.(Unknown Source)
at org.reprap.machines.GCodeRepRap.(Unknown Source)
at org.reprap.machines.MachineFactory.create(Unknown Source)
at org.reprap.Main.(Unknown Source)
at org.reprap.Main$9.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:641)
at java.awt.EventQueue.access$000(EventQueue.java:84)
at java.awt.EventQueue$1.run(EventQueue.java:602)
at java.awt.EventQueue$1.run(EventQueue.java:600)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:611)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Re: Verbindungsabbruch August 25, 2011 06:51AM |
