[Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 08:21AM |
#define X_ENDSTOP_INVERTING false #define Y_ENDSTOP_INVERTING false #define Z_ENDSTOP_INVERTING false #define X_STEPS_PER_MM (8.05*2) // (8.05*8) #define X_STEPS_PER_INCH (X_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_X_DIR 0 #define Y_STEPS_PER_MM (8.05*2) // (8.05*16) #define Y_STEPS_PER_INCH (Y_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Y_DIR 0 #define Z_STEPS_PER_MM (640*2) // (640*8) #define Z_STEPS_PER_INCH (Z_STEPS_PER_MM*INCHES_TO_MM) // *RO #define INVERT_Z_DIR 0 // Stepper-driven extruder // E_STEPS_PER_MM is the number of steps needed to // extrude 1mm out of the nozzle. E0 for extruder 0; // E1 for extruder 1, and so on. //#define E_STEPS_PER_MM 0.9 // NEMA 17 extruder 5mm diameter drive - empirically adjusted #define E0_STEPS_PER_MM (2.2*8) // NEMA 17 59/11 geared extruder 8mm diameter drive #define E1_STEPS_PER_MM 2.2 // NEMA 17 59/11 geared extruder 8mm diameter drive
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 08:24AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 08:56AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 09:17AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 09:23AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 09:28AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 09:45AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 11:06AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 12:01PM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD August 31, 2011 12:23PM |
Muss ich die Baudrate mit der von der Teacup Firmware abgleichen?
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD September 01, 2011 10:35AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD September 01, 2011 10:55AM |
Oder müssen zwingend irgendwelche Kabel und die MotorTreiber auf dem Board sitzen? Vom Prinzip sind bisher bei mir nur die 3 Stromstecker und das USB Breakout angeschlossen ^^
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD September 01, 2011 11:36AM |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD September 01, 2011 11:58AM |
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD September 01, 2011 01:29PM |
habe nämlich da wo die Temperatursensoren sind, die zwei Kondensatoren angelötet. Nu muss ich erstmal auf meine Entlötpumpe warten, um die wieder entfernen zu können.
Allerdings bin ich im mom der Meinung, dass ich gar keine Sensoren für die Temperatur habe ^^
Habe ja vom Prinzip nur die Heizdüse im Extruder.
Re: [Einstellungen/Fehler] Prusa Elektronik Gen7 - FiveD September 01, 2011 02:44PM |
