Fine Tuning questo sconosciuto February 21, 2018 02:40AM |
Re: Fine Tuning questo sconosciuto February 21, 2018 04:38AM |
).Quote
Luca Benedetto su Thingiverse
in the last two years I’ve help lot of people to fine tune their GEEETech i3 series printer, and lot of time the solution, solved the “normal issues”, was the same… better calibration!
Each single time I give to people ask my help always the same identical instruction in order to do a better calibration, so now I’ve decided to directly share stl I normally use during calibration and write down instruction!
In this kit you’ll find:
Regular 100x100, and 100x100x100, brackets useful to calculate the exact value of Marlin’s STEPS_PER_UNIT define for your printer
Standard 20x20x10x1 calibration parallelepiped useful to calculate right value for Slic3R Extrusion Multiplier
The Excel spreadsheet with the automation of all calculations for STEPS_PER_UNIT and Extrusion Multiplier Calibration
IF YOU “FALL IN LOVE” OF ONE OF MY DESIGNS AND TRICS, PLEASE, REMEMBER THAT IT TAKE TIME TO BE CREATED, DESIGNED AND SHARED… SO “MAYBE” YOU CAN USE THE “TIP DESIGNED” BUTTON ON MY PROFILE!
Parti rivedute in rosso, come a scuola
in the last two years I helped a lot of people to fine tune their GEEETech i3 series printer, and many times (oppure "a lot of times" se vuoi fare un'allitterazione di "lot") the solution, that solved the “normal issues”, was the same… better calibration!
Every (single*) time people ask my help I always give them the same identical instructions in order to do a better calibration, so now I’ve decided to directly share stl I normally use during calibration and write down instructions!
IF YOU “FALL IN LOVE” WITH ONE OF MY DESIGNS AND TRIKS, PLEASE, REMEMBER THAT IT TOOK TIME TO BE CREATED, DESIGNED AND SHARED… SO “MAYBE” YOU CAN USE THE “TIP DESIGNER” BUTTON ON MY PROFILE!
*la presenza di "single" qua sembra dare un tono piú esasperato alla frase.
Re: Fine Tuning questo sconosciuto February 22, 2018 12:08AM |
Re: Fine Tuning questo sconosciuto February 22, 2018 01:52AM |
Frankq
Bravo, l'hai fatto in inglese
Re: Fine Tuning questo sconosciuto February 22, 2018 04:14AM |
Dammi un po' di tempo e gli faró anche la traduzione in russo.Quote
Frankq
E non dimentichiamoci il russo, Putin và forte, e poi un occhio al cinese ragazzi.
Beh, insomma...Quote
Luca_Benedetto
volontariamente maccheronico così anche chi dall'Italia non mastica troppo la lingua della perfida Albione ci si possa raccapezzare facilmente.
Re: Fine Tuning questo sconosciuto February 22, 2018 06:05PM |
Re: Fine Tuning questo sconosciuto February 22, 2018 06:14PM |
Re: Fine Tuning questo sconosciuto February 23, 2018 06:19AM |
Re: Fine Tuning questo sconosciuto February 23, 2018 07:35AM |
... e ve lo dice uno che non solo ha i maccheroni in bocca..... ma anche i tortellini... quindi quando scrivo in inglese lo scrivo "tortellinico".......
.... ma su quella piattaforma non lo vedo bene il regionalismo linguistico.....
Re: Fine Tuning questo sconosciuto February 23, 2018 10:41AM |
Re: Fine Tuning questo sconosciuto February 24, 2018 02:28AM |
Re: Fine Tuning questo sconosciuto February 24, 2018 08:12AM |
Frankq
Ciao a tutti
ritorno un'ultima volta su questo argomento e poi chiudo.
Abbiamo un FAQ e guide che raccoglie consigli e tutorial; è lì che andava messo l'articolo in questione, perchè questo è il nostro forum.
Io non collaboro molto, la mia età mi taglia fuori da tante cose, intervengo solo su argomenti che conosco come l'elettronica spicciola, ma se dovessi scrivere un tutorial lo posterei in FAQ e guide.
Successivamente, se lo ritenessi sufficentemente valido, lo posterei su Thingiverse.
Saluti
Franco
Re: Fine Tuning questo sconosciuto February 24, 2018 08:24AM |
Luca_Benedetto
Se il topic da fastidio non ho problemi a toglierlo...
Gordie, per favore provevdi te come amministratore a rimuoverlo?
Re: Fine Tuning questo sconosciuto April 20, 2018 10:41AM |
Moderator Registered: 12 years ago Posts: 1,865 |
Re: Fine Tuning questo sconosciuto September 18, 2019 06:53AM |
