problema heatbed con temperatura fissa November 10, 2014 06:32PM |
Re: problema heatbed con temperatura fissa November 11, 2014 02:36AM |
Re: problema heatbed con temperatura fissa November 11, 2014 03:09AM |
Re: problema heatbed con temperatura fissa November 11, 2014 03:20AM |
Re: problema heatbed con temperatura fissa November 11, 2014 04:39AM |
Re: problema heatbed con temperatura fissa November 11, 2014 05:31AM |
Re: problema heatbed con temperatura fissa November 11, 2014 05:34AM |
Re: problema heatbed con temperatura fissa November 11, 2014 05:38AM |
Re: problema heatbed con temperatura fissa November 11, 2014 05:49AM |
Re: problema heatbed con temperatura fissa November 11, 2014 06:26AM |
Re: problema heatbed con temperatura fissa November 11, 2014 06:32AM |
Re: problema heatbed con temperatura fissa November 11, 2014 07:25AM |
Re: problema heatbed con temperatura fissa November 11, 2014 07:31AM |
Re: problema heatbed con temperatura fissa November 11, 2014 07:55AM |
corso_shiba
acio88
Poi presto vi darò delle dritte sulla cavetteria speciale (che produco io) per avere una 3d Printer davvero ottima..
Grazie
Andrea
Però così ci tieni sulle spine......
Speriamo presto perché io ancora non ho provveduto
Re: problema heatbed con temperatura fissa November 11, 2014 08:06AM |
Molto interessato|
Re: problema heatbed con temperatura fissa November 11, 2014 09:21AM |
Re: problema heatbed con temperatura fissa November 11, 2014 09:25AM |
Re: problema heatbed con temperatura fissa November 11, 2014 04:51PM |
Re: problema heatbed con temperatura fissa November 11, 2014 07:26PM |
Re: problema heatbed con temperatura fissa November 11, 2014 07:28PM |
Re: problema heatbed con temperatura fissa November 11, 2014 07:35PM |
Re: problema heatbed con temperatura fissa November 11, 2014 07:59PM |
Re: problema heatbed con temperatura fissa November 12, 2014 02:17AM |
Re: problema heatbed con temperatura fissa November 12, 2014 03:44AM |
MagoKimbra
Acio cerca di essere preciso, altrimenti non si capisce nulla...
Hai invertito i pin giusto nel fw quindi la sonda del bed diventa la sonda dell'hotend e viceversa... Ora è la sonda dell'hotend che non va giusto?
Quindi è qualcosa di hardware sulla scheda o si è rotto il condensatore o proprio l'AD del processore...
Re: problema heatbed con temperatura fissa November 12, 2014 04:44AM |
Re: problema heatbed con temperatura fissa November 12, 2014 06:07AM |
MagoKimbra
[attachment 43553 1000px-Melzi2.jpg]
Quello giallo è il condensatore quella piccolina a sinistra è la resistenza... Controlla con un tester il valore della resistenza, ma non credo che quella abbia problemi. Invece il condensatore dovrebbe essere un valore infinito come resistenza...
[attachment 43554 Melzi-circuit.jpg]
Re: problema heatbed con temperatura fissa November 12, 2014 06:10AM |
Re: problema heatbed con temperatura fissa November 12, 2014 06:15AM |
MagoKimbra
Re: problema heatbed con temperatura fissa November 12, 2014 06:38AM |
Re: problema heatbed con temperatura fissa November 12, 2014 07:00AM |
