come migliorare?
December 30, 2014 06:32AM
salve a tutti ... torno a rompere ... grinning smiley
chi mi aiuta a migliorare la qualità?
questi i parametri ... il riempimento dovrebbe essere a nido d'ape e in realtà è una linea molto confusa, le pareti laterali sono distanti tra loro e un'altra marea di difetti si notano dalla foto. E' ABS 3mm a 265° con hotend IeC da 0.35 su una i2.
; bed_temperature = 108
; brim_width = 2
; filament_diameter = 2.6
; first_layer_acceleration = 0
; first_layer_bed_temperature = 108
; first_layer_extrusion_width = 200%
; first_layer_speed = 30%
; first_layer_temperature = 260
; infill_acceleration = 0
; infill_first = 0
; min_print_speed = 10
; min_skirt_length = 0
; nozzle_diameter = 0.35
; only_retract_when_crossing_perimeters = 1
; resolution = 0
; retract_before_travel = 2
; retract_layer_change = 1
; retract_length = 2
; retract_length_toolchange = 10
; retract_lift = 0
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 0
; retract_speed = 60
; skirt_distance = 6
; skirt_height = 1
; skirts = 5
; temperature = 260
; travel_speed = 120
; z_offset = 0
; extrusion_width = 0
; first_layer_height = 0.3
; infill_only_where_needed = 0
; interface_shells = 0
; layer_height = 0.15
; raft_layers = 0
; bottom_solid_layers = 3
; external_perimeter_extrusion_width = 0
; external_perimeter_speed = 50%
; external_perimeters_first = 0
; extra_perimeters = 1
; fill_angle = 45
; fill_density = 70%
; fill_pattern = honeycomb
; gap_fill_speed = 20
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0
; infill_speed = 60
; overhangs = 1
; perimeter_extruder = 1
; perimeter_extrusion_width = 0
; perimeter_speed = 20
; perimeters = 6
; small_perimeter_speed = 20
; solid_fill_pattern = rectilinear
; solid_infill_below_area = 70
; solid_infill_every_layers = 0
; solid_infill_extrusion_width = 0
; solid_infill_speed = 40
; thin_walls = 1
; top_infill_extrusion_width = 0
; top_solid_infill_speed = 40
; top_solid_layers = 3
sempre grazie a tutti e auguri
mentre aspettavo ho trovato almeno un perchè dell'irregolarità ... cinghia di Y lasca ....
Edited 1 time(s). Last edit at 12/30/2014 08:01AM by giggi.
[www.3deasy.it]
[www.facebook.com]
[www.instagram.com]
i2 hotend IeC 0.4mm - 3 mm - Repetier-Host - MarlinKimbra - Megatronics v2 - A4988
3deasy.1 hotend IeC V.4 0.4mm (bowden) - 3 mm - Repetier-Host - MarlinKimbra - RAMPS 1.4 + Arduino - DRV8825
3deasy.2 hotend IeC V.4 0.4mm (bowden) - 1.75 mm - Repetier-Host - MarlinKimbra - RAMPS 1.4 + Arduino - DRV8825
