ABS stampa con "gocce"
May 15, 2016 03:59AM
Ciao a tutti!
sto stampanto dell'ABS, (filo molto asciutto non scoppietta), non riesco a rimuovere quelle gocce che vedete ai bordi del pezzo, mi date consigli?
è possibile che se stampo da layer height 0.1 a 0.2 gli strati del pezzo non reggono? sbaglio qualcosa?
Aspetto vostri consigli grazie!
la foto la trovate QUI
Mendelmax 2
Ramps 1.4 - Driver 8825 - Hotend J-head 3mm 0.5 - Firmware Marlin 1.1 - Cura engine - Repetier Host
open | download - ABS.ini (10.5 KB)
Re: ABS stampa con "gocce"
May 15, 2016 06:22AM
Penso che sia un problema di temperature troppo elevate.. il file ini non lo apro, mi puoi dire a quale temperatura stampi? smiling smiley
Andrea Lillia
Lillia.net
Pagina Facebook
May 15, 2016 08:44AM
Stampo a 2.40 posto il file ini
profile]
layer_height = 0.1
wall_thickness = 1.0
retraction_enable = True
solid_layer_thickness = 1
fill_density = 100
nozzle_size = 0.5
print_speed = 45
print_temperature = 240
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 75
support = None
platform_adhesion = Brim
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 2.85
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100.0
retraction_speed = 120.0
retraction_amount = 7.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0.3
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 70
bottom_layer_speed = 20
infill_speed = 0.0
solidarea_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 5
fan_enabled = False
skirt_line_count = 8
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
perimeter_before_infill = False
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 40
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.22
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode =
	;Print time: {print_time}
	;Filament used: {filament_amount}m {filament_weight}g
	;Filament cost: {filament_cost}
	G1 Z10 F3000 ; mi alzo per sicurezza
	G28 ; home su tutti gli assi
	G1 X1 Y1 Z10 F3000 ;mi sposto al bordo
	G1 Z0 F3000; vado a terra
	G90 ; use absolute coordinates
	G21 ; set units to millimeters
	G92 E0
	M82 ; use absolute distances for extrusion
	M190 S{print_bed_temperature} ; wait for bed temperature
	M109 S{print_temperature} ; wait for temperature to be reached
	G1 E10 F400 ; prime the nozzle
end.gcode =
	M104 S0                     ;extruder heater off
	M140 S0                     ;heated bed heater off (if you have it)
	G91                                    ;relative positioning
	G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
	G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
	G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
	M84                         ;steppers off
	G90                         ;absolute positioning
start2.gcode = ;Sliced at: {day} {date} {time}
	;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
	;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
	;M104 S{print_temperature} ;Uncomment to add your own temperature line
	;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
	;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
	G21        ;metric values
	M107       ;start with the fan off
	G28 Z0     ;move Z to min endstops
	G1 Z15.0 F{travel_speed} ;move the platform down 15mm
	T1                      ;Switch to the 2nd extruder
	G92 E0                  ;zero the extruded length
	G1 F200 E10             ;extrude 10mm of feed stock
	G92 E0                  ;zero the extruded length again
	G1 F200 E-{retraction_dual_amount}
	T0                      ;Switch to the first extruder
	G1 F{travel_speed}
	;Put printing message on LCD screen
	M117 Printing...
end2.gcode = ;End GCode
	M104 T0 S0                     ;extruder heater off
	M104 T1 S0                     ;extruder heater off
	M84                         ;steppers off
	;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
	G21        ;metric values
	T2                      ;Switch to the 2nd extruder
	G1 F{travel_speed}
	M117 Printing...
end3.gcode = ;End GCode
	M104 T2 S0                     ;extruder heater off
	M84                         ;steppers off
	;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
	;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
	G21        ;metric values
	T3                      ;Switch to the 4th extruder
	T2                      ;Switch to the 3th extruder
	G1 F{travel_speed}
	M117 Printing...
end4.gcode = ;End GCode
	M104 T3 S0                     ;extruder heater off
	M84                         ;steppers off
	;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
	;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
	;This code is added after the T(n)
May 15, 2016 10:07AM
Ti ringrazio smiling smiley Puoi provare a scendere a 230 con la temperatura, dovrebbe andare tutto benissimo, effettua una prova di estrusione però prima di lanciare la stampa, il filamento deve scendere e formare dei bei cerchi dove cade smiling smiley
Andrea Lillia
Lillia.net
Pagina Facebook
