Problema estrusore: troppo filamento estruso November 23, 2016 08:30PM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 12:32AM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 04:05AM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 04:25AM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 04:46AM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 05:04AM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 05:11AM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 05:13AM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 07:59PM |
Re: Problema estrusore: troppo filamento estruso November 24, 2016 11:59PM |
Re: Problema estrusore: troppo filamento estruso November 25, 2016 12:18PM |
Re: Problema estrusore: troppo filamento estruso November 26, 2016 12:13PM |
Re: Problema estrusore: troppo filamento estruso November 26, 2016 12:50PM |
Re: Problema estrusore: troppo filamento estruso November 26, 2016 03:31PM |
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table // //// Temperature sensor settings: // -3 is thermocouple with MAX31855 (only for sensor 0) // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is Mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // 11 is 100k beta 3950 1% thermistor (4.7k pullup) // 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed) // 13 is 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE" // 20 is the PT100 circuit found in the Ultimainboard V2.x // 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950 // 66 is 4.7M High Temperature thermistor from Dyze Design // 70 is the 100K thermistor found in the bq Hephestos 2 // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup) // // 1047 is Pt1000 with 4k7 pullup // 1010 is Pt1000 with 1k pullup (non standard) // 147 is Pt100 with 4k7 pullup // 110 is Pt100 with 1k pullup (non standard) // 998 and 999 are Dummy Tables. They will ALWAYS read 25°C or the temperature defined below. // Use it for Testing or Development purposes. NEVER for production machine. //#define DUMMY_THERMISTOR_998_VALUE 25 //#define DUMMY_THERMISTOR_999_VALUE 100 #define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_BED 1
Re: Problema estrusore: troppo filamento estruso November 27, 2016 07:50PM |
Re: Problema estrusore: troppo filamento estruso November 28, 2016 04:53AM |
Re: Problema estrusore: troppo filamento estruso November 28, 2016 05:04AM |
Re: Problema estrusore: troppo filamento estruso December 05, 2016 03:11PM |
Re: Problema estrusore: troppo filamento estruso December 06, 2016 04:58AM |
Re: Problema estrusore: troppo filamento estruso December 06, 2016 05:53AM |
Re: Problema estrusore: troppo filamento estruso December 06, 2016 05:55AM |
bilanciamist
non hai qualcuno in famiglia che usa l'acetone per levare lo smalto dalle unghie? Non serve per forza che compri l'acetone puro in vendita in ferramenta, almeno per provare se è abs...
Ti consiglio di fare questa prova prima di continuare, perchè o è pla oppure hai problemi al termistore, quindi eviterei di fare prove a caso con la temperatura...
bilanciamist
Per l'autobed non so aiutarti, ma il letto riscaldante in metallo non viene letto dal sensore? c'è bisogno dell'alluminio?
bilanciamist
Quando hai sistemato i problemi sul materiale potresti anche pensare di passare al firmware mk.
Re: Problema estrusore: troppo filamento estruso December 06, 2016 06:07AM |
MagoKimbra
Si infatti il problema è che in quel punto sotto al piatto c'è una massa metallica maggiore che viene rilevata molto prima degli altri tre punti e quindi ti da un'altezza sbagliata...
Quei sensori vanno bene, ma si deve fare molta attenzione al piatto stesso...
Nella Prusa I3 MK2 per esempio è stato messo all'interno del piatto scaldante dei punti metallici dove poter fare la sonda, cosi nel tuo caso hai dei problemi grossi, il piatto in vetroresina o quello che sia, con delle piste all'interno che potrebbero essere sentite o no dalla sonda e il piatto metallico sotto..
La cosa migliore è mettere un foglio d'alluminio sopra al piatto scaldante e poi il vetro...
Re: Problema estrusore: troppo filamento estruso December 06, 2016 08:59AM |
dont_go_away
Per fortuna che ho preso un sensore che, sul datasheet, aveva scritto che aveva una distanza di rilevazione di 8mm
Re: Problema estrusore: troppo filamento estruso December 07, 2016 09:24AM |
Re: Problema estrusore: troppo filamento estruso December 10, 2016 06:14AM |
Re: Problema estrusore: troppo filamento estruso December 10, 2016 07:31AM |
Re: Problema estrusore: troppo filamento estruso December 10, 2016 08:07AM |
Re: Problema estrusore: troppo filamento estruso December 10, 2016 10:51AM |
Re: Problema estrusore: troppo filamento estruso December 17, 2016 11:37AM |
Re: Problema estrusore: troppo filamento estruso December 28, 2016 12:01PM |
