MK4duo e LIN_ADVANCE non si compila September 10, 2017 11:11AM |
Arduino:1.8.4 (Mac OS X), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Opzioni di compilazione cambiate, ricompilo tutto
In file included from sketch/src/../base.h:81:0,
from sketch/src/MK_Main.cpp:31:
sketch/src/MK_Main.cpp: In function 'bool pin_is_protected(uint8_t)':
sketch/src/../src/pins.h:419:24: warning: narrowing conversion of '173' from 'int' to 'const int8_t {aka const signed char}' inside { } [-Wnarrowing]
sketch/src/MK_Main.cpp:423:50: note: in expansion of macro 'SENSITIVE_PINS'
static const int8_t sensitive_pins[] PROGMEM = SENSITIVE_PINS;
sketch/src/../src/pins.h:419:24: warning: narrowing conversion of '174' from 'int' to 'const int8_t {aka const signed char}' inside { } [-Wnarrowing]
sketch/src/../src/pins.h:419:24: warning: narrowing conversion of '159' from 'int' to 'const int8_t {aka const signed char}' inside { } [-Wnarrowing]
sketch/src/MK_Main.cpp: In function 'void gcode_M900()':
sketch/src/MK_Main.cpp:8135:28: error: 'class Planner' has no member named 'extruder_advance_k'
if (newK >= 0) planner.extruder_advance_k = newK;
sketch/src/MK_Main.cpp:8145:28: error: 'class Planner' has no member named 'advance_ed_ratio'
if (newR >= 0) planner.advance_ed_ratio = newR;
In file included from sketch/src/../src/HAL/HAL.h:42:0,
from sketch/src/../base.h:85,
sketch/src/MK_Main.cpp:8147:44: error: 'class Planner' has no member named 'extruder_advance_k'
SERIAL_SMV(ECHO, "Advance K=", planner.extruder_advance_k);
sketch/src/../src/HAL/HAL_AVR/communication.h:68:75: note: in definition of macro 'SERIAL_MV'
#define SERIAL_MV(msg, val, ...) (serial_print_pair(PSTR(msg), val, ## __VA_ARGS__))
sketch/src/MK_Main.cpp:8147:5: note: in expansion of macro 'SERIAL_SMV'
sketch/src/MK_Main.cpp:8149:17: error: 'class Planner' has no member named 'advance_ed_ratio'
if (planner.advance_ed_ratio) SERIAL_VAL(planner.advance_ed_ratio);
from sketc
sketch/src/MK_Main.cpp:8149:54: error: 'class Planner' has no member named 'advance_ed_ratio'
sketch/src/../src/HAL/HAL_AVR/communication.h:61:59: note: in definition of macro 'SERIAL_VAL'
#define SERIAL_VAL(val, ...) (serial_print(val, ## __VA_ARGS__))
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Re: MK4duo e LIN_ADVANCE non si compila September 10, 2017 12:35PM |
Re: MK4duo e LIN_ADVANCE non si compila September 10, 2017 01:10PM |
Re: MK4duo e LIN_ADVANCE non si compila September 10, 2017 05:10PM |
Re: MK4duo e LIN_ADVANCE non si compila September 10, 2017 06:09PM |
"/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp.o"
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp: In function 'void gcode_M900()':
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp:8135:28: error: 'class Planner' has no member named 'extruder_advance_k'
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp:8145:28: error: 'class Planner' has no member named 'advance_ed_ratio'
In file included from /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/../src/HAL/HAL.h:42:0,
from /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/../base.h:85,
from /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp:31:
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp:8147:44: error: 'class Planner' has no member named 'extruder_advance_k'
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/../src/HAL/HAL_AVR/communication.h:68:75: note: in definition of macro 'SERIAL_MV'
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp:8147:5: note: in expansion of macro 'SERIAL_SMV'
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp:8149:17: error: 'class Planner' has no member named 'advance_ed_ratio'
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/MK_Main.cpp:8149:54: error: 'class Planner' has no member named 'advance_ed_ratio'
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_769529/sketch/src/../src/HAL/HAL_AVR/communication.h:61:59: note: in definition of macro 'SERIAL_VAL'
exit status 1
In file included from /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/../../base.h:111:0,
from /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/mechanics.cpp:29:
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/../../src/planner/planner.h: In member function 'void Mechanics::_set_position_mm(const float&, const float&, const float&, const float&)':
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/../../src/planner/planner.h:189:20: error: 'float Planner::position_float [4]' is private
static float position_float[NUM_AXIS];
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/mechanics.cpp:51:13: error: within this context
planner.position_float[X_AXIS] = a;
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/mechanics.cpp:52:13: error: within this context
planner.position_float[Y_AXIS] = b;
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/mechanics.cpp:53:13: error: within this context
planner.position_float[Z_AXIS] = c;
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/mechanics.cpp:54:13: error: within this context
planner.position_float[E_AXIS] = e;
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/../../src/planner/planner.h: In member function 'void Mechanics::set_position_mm(AxisEnum, const float&)':
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_38604/sketch/src/mechanics/mechanics.cpp:73:13: error: within this context
planner.position_float[axis] = v;
exit status 1
In file included from /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/../../base.h:111:0,
from /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/mechanics.cpp:29:
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/../../src/planner/planner.h: In member function 'void Mechanics::_set_position_mm(const float&, const float&, const float&, const float&)':
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/../../src/planner/planner.h:189:20: error: 'float Planner::position_float [4]' is private
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/mechanics.cpp:51:13: error: within this context
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/mechanics.cpp:52:13: error: within this context
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/mechanics.cpp:53:13: error: within this context
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/mechanics.cpp:54:13: error: within this context
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/../../src/planner/planner.h: In member function 'void Mechanics::set_position_mm(AxisEnum, const float&)':
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T/arduino_build_789726/sketch/src/mechanics/mechanics.cpp:73:13: error: within this context
exit status 1
Re: MK4duo e LIN_ADVANCE non si compila September 11, 2017 02:32AM |
Re: MK4duo e LIN_ADVANCE non si compila September 11, 2017 02:43AM |
Re: MK4duo e LIN_ADVANCE non si compila September 11, 2017 02:52AM |
Re: MK4duo e LIN_ADVANCE non si compila September 11, 2017 03:58AM |
Re: MK4duo e LIN_ADVANCE non si compila September 11, 2017 05:10AM |
Re: MK4duo e LIN_ADVANCE non si compila September 11, 2017 08:40AM |
/var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T//ccTS92y9.ltrans2.ltrans.o: In function `EEPROM::Factory_Settings()': ccTS92y9.ltrans2.oversione arduino :1.8.4.text+0x256): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0x25a): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0x25e): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0x262): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0x28e): undefined reference to `retract_recover_feedrate' ccTS92y9.ltrans2.o
.text+0x292): undefined reference to `retract_recover_feedrate' ccTS92y9.ltrans2.o
.text+0x296): undefined reference to `retract_recover_feedrate' ccTS92y9.ltrans2.o
.text+0x29a): undefined reference to `retract_recover_feedrate' /var/folders/4l/59hg5m0n1hg1t5drcv2y_93h0000gn/T//ccTS92y9.ltrans2.ltrans.o: In function `EEPROM:
rint_Settings(bool)': ccTS92y9.ltrans2.o
.text+0xbf2): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0xbf6): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0xbfa): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0xbfe): undefined reference to `retract_feedrate' ccTS92y9.ltrans2.o
.text+0xce6): undefined reference to `retract_recover_feedrate' ccTS92y9.ltrans2.o
.text+0xcea): undefined reference to `retract_recover_feedrate' ccTS92y9.ltrans2.o
.text+0xcee): undefined reference to `retract_recover_feedrate' ccTS92y9.ltrans2.o
.text+0xcf2): undefined reference to `retract_recover_feedrate' collect2: error: ld returned 1 exit status exit status 1 Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
