stampa schiacciata April 25, 2018 09:36AM |
Re: stampa schiacciata April 26, 2018 03:01AM |
Re: stampa schiacciata April 26, 2018 11:22AM |
Re: stampa schiacciata April 28, 2018 10:55AM |
Re: stampa schiacciata April 28, 2018 12:16PM |
Re: stampa schiacciata April 28, 2018 12:26PM |
Re: stampa schiacciata April 28, 2018 01:05PM |
Re: stampa schiacciata April 29, 2018 03:05AM |
teps per unit:
ID settings:|
Re: stampa schiacciata April 29, 2018 04:11AM |
Re: stampa schiacciata April 29, 2018 05:07AM |
nanigago
...quando lancio la stampa da scheda sd sembra che le ignori completamente.
Re: stampa schiacciata April 29, 2018 05:22AM |
M92 X160.00 Y160.00 Z5000.00 E1700.00
Re: stampa schiacciata April 29, 2018 05:37AM |
Re: stampa schiacciata April 29, 2018 05:40AM |
Re: stampa schiacciata April 29, 2018 05:50AM |
Re: stampa schiacciata April 29, 2018 06:07AM |
Re: stampa schiacciata April 29, 2018 09:42AM |
Re: stampa schiacciata April 29, 2018 10:24AM |
; generated by Slic3r 1.2.9 on 2018-04-13 at 14:57:38 ; external perimeters extrusion width = 0.40mm ; perimeters extrusion width = 0.48mm ; infill extrusion width = 0.48mm ; solid infill extrusion width = 0.48mm ; top infill extrusion width = 0.48mm M107 M190 S65 ; set bed temperature M104 S195 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle G92 E0 ; reset extruder G1 E3 F1200 ; prime extruder 3mm G1 E2 F1200 ; retract extruder 1mm G92 E0 ; reset extruder M109 S195 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 G1 Z0.350 F7800.000 G1 E-2.00000 F2400.00000 G92 E0 G1 X103.745 Y100.953 F7800.000 G1 E2.00000 F2400.00000
Re: stampa schiacciata April 29, 2018 10:41AM |
KIRT
Re: stampa schiacciata April 29, 2018 12:26PM |
nanigago
Ho rifatto tutte le misurazioni e effettivamente ero un po scarso sull'asse z ho portato a 8000 gli step.
Re: stampa schiacciata April 29, 2018 12:29PM |
Re: stampa schiacciata April 29, 2018 12:49PM |
Re: stampa schiacciata April 29, 2018 12:54PM |
bilanciamist
nanigago
Vabbè, ma mica puoi mettere valori a caso... il valore degli step come ho scritto prima dipende da vari fattori: motori, driver, cinghia o vite...
Una volta che hai messo il valore giusto (calcolato), se hai un movimento dell'asse diverso da quanto impostato allora hai una perdita di passi.
Se cambi il valore degli step per stare dietro alla perdita di passi non ne esci...
Re: stampa schiacciata April 30, 2018 08:15AM |
Re: stampa schiacciata May 01, 2018 07:41AM |
Re: stampa schiacciata May 01, 2018 08:15AM |
nanigago
Ciao ho smontato la scheda e controllato e non sono come credevo in full step ma ho sotto ogni driver tutti e 3 i ponticelli inseriti quindi secondo la guida RAMPS ho 1/128 step, domanda il prusa calcolator arriva fino a 1/32 io che valori dovrei impostargli per i calcoli corretti?
Re: stampa schiacciata May 01, 2018 09:03AM |
