Ad un tratto....problemi risclad. e temp. fuori controllo September 19, 2018 04:37PM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo September 20, 2018 10:32AM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo September 20, 2018 03:56PM |
// Check if temperature is within the correct range
soft_pwm[e] = (current_temperature[e] > minttemp[e] || is_preheating(e)) && current_temperature[e] < maxttemp[e] ? (int)pid_output >> 1 : 0;
// Check if the temperature is failing to increase
#if WATCH_HOTENDS
// Is it time to check this extruder's heater?
if (watch_heater_next_ms[e] && ELAPSED(ms, watch_heater_next_ms[e])) {
// Has it failed to increase enough?
if (degHotend(e) < watch_target_temp[e]) {
// Stop!
_temp_error(e, PSTR(MSG_T_HEATING_FAILED), PSTR(MSG_HEATING_FAILED_LCD));
else {
// Start again if the target is still far off
start_watching_heater(e);
#endif // THERMAL_PROTECTION_HOTENDS
#if WATCH_THE_BED
// Is it time to check the bed?
if (watch_bed_next_ms && ELAPSED(ms, watch_bed_next_ms)) {
if (degBed() < watch_target_bed_temp) {
// Stop!
_temp_error(-1, PSTR(MSG_T_HEATING_FAILED), PSTR(MSG_HEATING_FAILED_LCD));
else {
start_watching_bed();
int heater_index = heater_id >= 0 ? heater_id : HOTENDS;
// If the target temperature changes, restart
if (tr_target_temperature[heater_index] != target) {
tr_target_temperature[heater_index] = target;
*state = target > 0 ? TRFirstHeating : TRInactive;
switch (*state) {
// Inactive state waits for a target temperature to be set
case TRInactive: break;
// When first heating, wait for the temperature to be reached then go to Stable state
case TRFirstHeating:
if (current < tr_target_temperature[heater_index]) break;
*state = TRStable;
// While the temperature is stable watch for a bad temperature
case TRStable:
if (current >= tr_target_temperature[heater_index] - hysteresis_degc) {
*timer = millis() + period_seconds * 1000UL;
break;
else if (PENDING(millis(), *timer)) break;
*state = TRRunaway;
case TRRunaway:
_temp_error(heater_id, PSTR(MSG_T_THERMAL_RUNAWAY), PSTR(MSG_THERMAL_RUNAWAY));
Re: Ad un tratto....problemi risclad. e temp. fuori controllo September 20, 2018 06:09PM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo October 25, 2018 03:53PM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo October 27, 2018 03:24AM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo October 27, 2018 05:18AM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo October 27, 2018 05:44PM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo October 28, 2018 06:57AM |
Re: Ad un tratto....problemi risclad. e temp. fuori controllo December 04, 2018 05:13AM |
