Upgrading stepper motor for 80mm Spindle
Hey everyone,
Ordered the 80mm mount as I have a 80mm spindle I’d like to try. Given the weight, considering upgrading the Z-axis stepper and was wondering if there is any guidance on what size stepper I should look at. Given the buildbotics should be able to handle most of the comparable Nema 23 steppers of larger size, if I am ready correctly, seems like one of these should work:
https://www.oyostepper.it/goods-88-Motore-passo-passo-Nema-23-bipolare-18-gradi-3Nm-42A-57x57x114mm-Motore-passo-passo-CNC-a-4-fili.html
Thoughts?
Edited 1 time(s). Last edit at 04/01/2024 06:52AM by maogeken.
