heatbed funziona ad intermittenza December 30, 2015 01:45PM |
Re: heatbed funziona ad intermittenza December 31, 2015 12:03AM |
Re: heatbed funziona ad intermittenza December 31, 2015 02:49AM |
Re: heatbed funziona ad intermittenza December 31, 2015 06:39AM |
Re: heatbed funziona ad intermittenza December 31, 2015 08:01AM |
Re: heatbed funziona ad intermittenza December 31, 2015 09:49AM |
Re: heatbed funziona ad intermittenza December 31, 2015 10:20AM |
Re: heatbed funziona ad intermittenza December 31, 2015 10:22AM |
Re: heatbed funziona ad intermittenza December 31, 2015 10:30AM |
Re: heatbed funziona ad intermittenza December 31, 2015 10:36AM |
Re: heatbed funziona ad intermittenza December 31, 2015 10:56AM |
Re: heatbed funziona ad intermittenza January 05, 2016 01:31PM |
SENDING:M105 ok T:26.9 /0.0 B:30.2 /0.0 T0:26.9 /0.0 @:0 B@:0 Setting bed temperature to 90.000000 degrees Celsius. Setting hotend temperature to 210.000000 degrees Celsius. SENDING:M105 ok T:210.0 /210.0 B:49.3 /50.0 T0:210.0 /210.0 @:72 B@:127 SENDING:M105 ok T:210.0 /210.0 B:51.5 /50.0 T0:210.0 /210.0 @:71 B@:0 SENDING:M105 ok T:210.1 /210.0 B:50.9 /50.0 T0:210.1 /210.0 @:69 B@:0 SENDING:M105 ok T:210.1 /210.0 B:50.7 /50.0 T0:210.1 /210.0 @:69 B@:0 SENDING:M105 ok T:231.7 /240.0 B:14.5 /90.0 T0:231.7 /240.0 @:127 B@:0 SENDING:M105 ok T:240.0 /240.0 B:53.1 /90.0 T0:240.0 /240.0 @:83 B@:0 SENDING:M105 ok T:240.1 /240.0 B:16.5 /90.0 T0:240.1 /240.0 @:78 B@:127 SENDING:M105 ok T:239.9 /240.0 B:16.0 /90.0 T0:239.9 /240.0 @:85 B@:127 SENDING:M105 ok T:240.0 /240.0 B:100.5 /90.0 T0:240.0 /240.0 @:84 B@:0
Re: heatbed funziona ad intermittenza January 06, 2016 01:12PM |
Ma magari non c'è qualche falso contatto sul cavo che collega il termistore alla scheda?Quote
m_cipo
Grazie Magokimbra dei consigli, ma niente, da qualche giorno, dopo test e prove non so come, il problema sembra sparito, da solo... non so se è meglio o peggio, ma almeno ho ricominciato a stampare.
Comunque da quello che ho constatato con la stampante collegata a pronterface, nel riscaldare il piatto a 90° a metà del processo si è spento il led e sia il display sia sull'host mi indicava 14° (e in casa non fa meno di 22), quando poi (tipo 5/10 minuti) il led si è riacceso come temperatura rilevata dal termistore indicava 100, quindi oltre 10° sopra quella settata.
Ho capito che forse allora la resistenza del piatto continua comunque a scaldarsi, allora ho preso il tester per vedere e da allora non ha più presentato il problema.
Speriamo bene...
Re: heatbed funziona ad intermittenza January 09, 2016 07:27AM |
Re: heatbed funziona ad intermittenza February 18, 2016 05:04AM |
